I am curious how the millis() function works in Arduino and what it compiles to, however I couldn't find any good info on this (suggestions apretiated)
Is it a good idea to cache the output of millis? For exampe if I m checking it in a number of places inside the loop - would it be better to store it in a variable and just check that instead of calling the millis() function multiple times?
Or am I going to be creating extra overhead with and additional variable? (i.e. does the milis() map directly to the value in compiled code and it doesn't matter that it looks like a function call in Arduino?)
I usually save millis() to a variable at the start of loop() - mainly so that all the decisions are based on the same value in that iteration of loop().
I can't imagine there is a performance concern unless you want some very tight timing.
It would not take you long to write a short program to measure the "cost" of reading millis()
