Hello everyone,
Here’s my goal, its pretty simple - just a little prototype for a larger project…
I need to be able to control 9 servo’s from one board (Decimilia) independently. I’m a bit new at writing code however, so my approach was to write separate functions for each servo, and then call those functions in a main loop in whatever order was necessary to achieve the desired effect.
I have some code that simply runs all of them at once, (just a test to see if my power supply was sufficient) -
how could I modify this or re-write the code to get independent control and get to a choreographed sequence of actuations?
#define SERVOa 13
#define SERVOb 12
#define SERVOc 11
#define SERVOd 10
#define SERVOe 9
#define SERVOf 8
#define SERVOg 7
#define SERVOh 6
#define SERVOi 5
#define MIN_PULSE 600
#define MAX_PULSE 2400
#define DELTA 1800
int lastPulse = 0;
int refreshTime = 20;
long randNumber;
int i;
pinMode(SERVOa, OUTPUT);
pinMode(SERVOb, OUTPUT);
pinMode(SERVOc, OUTPUT);
pinMode(SERVOd, OUTPUT);
pinMode(SERVOe, OUTPUT);
pinMode(SERVOf, OUTPUT);
pinMode(SERVOg, OUTPUT);
pinMode(SERVOh, OUTPUT);
pinMode(SERVOi, OUTPUT);
digitalWrite(SERVOa, LOW);
digitalWrite(SERVOb, LOW);
digitalWrite(SERVOc, LOW);
digitalWrite(SERVOd, LOW);
digitalWrite(SERVOe, LOW);
digitalWrite(SERVOf, LOW);
digitalWrite(SERVOg, LOW);
digitalWrite(SERVOh, LOW);
digitalWrite(SERVOi, LOW);
for (i=0; i<10; i++)
digitalWrite(SERVOa, HIGH);
digitalWrite(SERVOb, HIGH);
digitalWrite(SERVOc, HIGH);
digitalWrite(SERVOd, HIGH);
digitalWrite(SERVOe, HIGH);
digitalWrite(SERVOf, HIGH);
digitalWrite(SERVOg, HIGH);
digitalWrite(SERVOh, HIGH);
digitalWrite(SERVOi, HIGH);
delayMicroseconds((MIN_PULSE + MAX_PULSE)/2);
delay(20);
Serial.println("servo should be at center");
delay(20);
int i;
static int pulse_width;
randNumber = random(600, 2400);
delay(3000);
pulse_width = randNumber;
Serial.println(pulse_width, DEC);
if (millis() - lastPulse >= refreshTime) {
delayMicroseconds(pulse_width);
delay(20);
lastPulse = millis();
for (i=0; i<100; i++)
delay(20);
thanks in advance !!
