Peristaltic Pump With L298N
Hello all,
I am new to arduino. I am undergoing internship. I am designing a system in which I'm using Peristaltic Pump with L298N.
I am facing problem to configure my pump with L298N.
My Pump is 24v DC and in L298N is shown 12V DC.
How can I calibrate the require power for pump through L298N ???
Plz help me in this regards...
Thanks in advance..
ashu9314:
The L298 is an H-bridge. So you want to pump both ways?
If you only want to pump one way, then use a logic level mosfet.
Fourth diagram on this page.
ashu9314:
The L298 is rated for 46volt max.
The board/module that it's mounted on could have parts (capacitors) of a lower voltage.
Select a module that can handle that pump voltage.
Leo..
What are the specs on your pump motor?
Tom... :slight_smile:
