Hey all!
If you've worked with computer graphics, you've probably run across Perlin Noise before. It's great for making clouds and other textures. It's also a nice way to add the illusion of life to motion, etc. in a way that's a lot less random than, well, random().
I wrote the following Perlin Noise generator for the Arduino. Now all the fun of Processing's noise() function is at your command on the chip!
Any additions, changes, corrections, etc. are highly appreciated. And DEFINITELY let me know if you use this for something cool!
See:
http://freespace.virgin.net/hugo.elias/models/m_perlin.html
for the source of the algorithm I implemented and a great walkthrough of how to use it.
copyright 2007 Mike Edwards
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; version 2 of the License.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
#include <math.h>
float x1,y1,x2,y2,persistence;
int octaves;
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
analogWrite(5,0);
analogWrite(6,0);
//persistence affects the degree to which the "finer" noise is seen
persistence = 0.25;
//octaves are the number of "layers" of noise that get computed
octaves = 3;
x1 = float(millis())/100.0f;
y1 = 10.0f;
x2 = float(millis())/100.0f;
y2 = 11.0f;
//PerlinNoise2 results in a float between -1 and 1
//below we convert to a n int between 0 and 255
int m = int(PerlinNoise2(x1,y1,persistence,octaves)*128+128);
int n = int(PerlinNoise2(x2,y2,persistence,octaves)*128+128);
analogWrite(5,m);
analogWrite(6,n);
delay(5);
//using the algorithm from http://freespace.virgin.net/hugo.elias/models/m_perlin.html
// thanks to hugo elias
float Noise2(float x, float y)
long noise;
noise = x + y * 57;
noise = pow(noise << 13,noise);
return ( 1.0 - ( long(noise * (noise * noise * 15731L + 789221L) + 1376312589L) & 0x7fffffff) / 1073741824.0);
float SmoothNoise2(float x, float y)
float corners, sides, center;
corners = ( Noise2(x-1, y-1)+Noise2(x+1, y-1)+Noise2(x-1, y+1)+Noise2(x+1, y+1) ) / 16;
sides = ( Noise2(x-1, y) +Noise2(x+1, y) +Noise2(x, y-1) +Noise2(x, y+1) ) / 8;
center = Noise2(x, y) / 4;
return (corners + sides + center);
float InterpolatedNoise2(float x, float y)
float v1,v2,v3,v4,i1,i2,fractionX,fractionY;
long longX,longY;
longX = long(x);
fractionX = x - longX;
longY = long(y);
fractionY = y - longY;
v1 = SmoothNoise2(longX, longY);
v2 = SmoothNoise2(longX + 1, longY);
v3 = SmoothNoise2(longX, longY + 1);
v4 = SmoothNoise2(longX + 1, longY + 1);
i1 = Interpolate(v1 , v2 , fractionX);
i2 = Interpolate(v3 , v4 , fractionX);
return(Interpolate(i1 , i2 , fractionY));
float Interpolate(float a, float b, float x)
//cosine interpolations
return(CosineInterpolate(a, b, x));
float LinearInterpolate(float a, float b, float x)
return(a*(1-x) + b*x);
float CosineInterpolate(float a, float b, float x)
float ft = x * 3.1415927;
float f = (1 - cos(ft)) * .5;
return(a*(1-f) + b*f);
float PerlinNoise2(float x, float y, float persistance, int octaves)
float frequency, amplitude;
float total = 0.0;
for (int i = 0; i <= octaves - 1; i++)
frequency = pow(2,i);
amplitude = pow(persistence,i);
total = total + InterpolatedNoise2(x * frequency, y * frequency) * amplitude;
return(total);
