permanent USB TX
Hello all
i used a gamepad demo code, which only sends TX through USB if i press a button.
I changed it to only use one button which it does put on and off if i press it.
It works but i noticed that my simple code sends continuous through USB, that can’t be good.
But i don’t get why the demo code i used didn’t.
So here are the two codes.
I hope you can tell me why.
  Copyright (c) 2014-2015 NicoHood
  See the readme for credit to other people.
  Gamepad example
  Press a button and demonstrate Gamepad actions
  See HID Project documentation for more infos
  https://github.com/NicoHood/HID/wiki/Gamepad-API
#include "HID.h"
#include "HID-Project.h"
const int pinLed = LED_BUILTIN;
const int pinButton = 2;
  pinMode(pinLed, OUTPUT);
  pinMode(pinButton, INPUT_PULLUP);
  // Sends a clean report to the host. This is important on any Arduino type.
  Gamepad.begin();
  if (!digitalRead(pinButton)) {
    digitalWrite(pinLed, HIGH);
    // Press button 1-32
    static uint8_t count = 0;
    count++;
    if (count == 33) {
      Gamepad.releaseAll();
      count = 0;
      Gamepad.press(count);
    // Move x/y Axis to a new position (16bit)
    Gamepad.xAxis(random(0xFFFF));
    Gamepad.yAxis(random(0xFFFF));
    // Go through all dPad positions
    // values: 0-8 (0==centered)
    static uint8_t dpad1 = GAMEPAD_DPAD_CENTERED;
    Gamepad.dPad1(dpad1++);
    if (dpad1 > GAMEPAD_DPAD_UP_LEFT)
    static int8_t dpad2 = GAMEPAD_DPAD_CENTERED;
    Gamepad.dPad2(dpad2--);
    if (dpad2 < GAMEPAD_DPAD_CENTERED)
      dpad2 = GAMEPAD_DPAD_UP_LEFT;
    // Functions above only set the values.
    // This writes the report to the host.
    Gamepad.write();
    // Simple debounce
    delay(300);
    digitalWrite(pinLed, LOW);
  Gamepad example
#include "HID.h"
int buttonstate = 0;
  Gamepad.begin();
buttonstate = digitalRead(pinButton);
  if (buttonstate == LOW)
    Gamepad.press(1);
   Gamepad.release(1);
    Gamepad.write();
    // Simple debounce
    delay(200);
Oh dear how do i put the code into code here ?
Click the (</>) symbol at top right then paste your code into the “code” box that appears.
It works but i noticed that my simple code sends continuous through USB, that can't be good.
Why can't it? Either you want continuous data, so use your code, or you don't, so use the other code.
Your looking for the button being held down or not. You should be looking the button changing from low to high or vice versa.
Mark
