Permission Denied
I am having the following message displayed
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Users\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10812 -build-path C:\Users\edwar\AppData\Local\Temp\arduino_build_999981 -warnings=none -build-cache C:\Users\edwar\AppData\Local\Temp\arduino_cache_459462 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\Users\Documents\Arduino\libraries\TinyGSM-0.10.5\examples\AllFunctions\AllFunctions.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Users\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10812 -build-path C:\Users\edwar\AppData\Local\Temp\arduino_build_999981 -warnings=none -build-cache C:\Users\edwar\AppData\Local\Temp\arduino_cache_459462 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\Users\Documents\Arduino\libraries\TinyGSM-0.10.5\examples\AllFunctions\AllFunctions.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\edwar\AppData\Local\Temp\arduino_build_999981\sketch\AllFunctions.ino.cpp" -o nul
Alternatives for TinyGsmClient.h: [TinyGSM-0.10.5@0.10.5]
ResolveLibrary(TinyGsmClient.h)
-> candidates: [TinyGSM-0.10.5@0.10.5]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-ID:\Users\Documents\Arduino\libraries\TinyGSM-0.10.5\src" "C:\Users\edwar\AppData\Local\Temp\arduino_build_999981\sketch\AllFunctions.ino.cpp" -o nul
AllFunctions:92:10: fatal error: D:\Users\Documents\Arduino\libraries\TinyGSM-0.10.5\src/TinyGsmClient.h: Permission denied
#include <TinyGsmClient.h>
compilation terminated.
Using library TinyGSM-0.10.5 at version 0.10.5 in folder: D:\Users\Documents\Arduino\libraries\TinyGSM-0.10.5
exit status 1
I have searched for duplicates, but cannot find currently
Hi I get the following error message:-
C:\Users\Edward\AppData\Local\Temp.arduinoIDE-unsaved2024811-24040-j7j4f9.d3p4\sketch_sep11a\sketch_sep11a.ino:1:10: fatal error: D:\Users\Edward\OneDrive\Documents\Arduino\libraries\Arduino_AdvancedAnalog\src/Arduino_AdvancedAnalog.h: Permission denied
#include <Arduino_AdvancedAnalog.h>
exit status 1
Compilation error: D:\Users\Edward\OneDrive\Documents\Arduino\libraries\Arduino_AdvancedAnalog\src/Arduino_AdvancedAnalog.h: Permission denied
I have made sure of folder permissions, but still get the above issue
What are you trying to do with the file? - edit it? Or run it as a program?
This happens on compiling a sketch
Perhaps it could be a known bug with placing Arduino libraries to shared OneDrive disk. Try to move your libraries folder elsewhere
Moved the folder to d: drive, still occurring
D:\Arduino\sketch_sep11a\sketch_sep11a.ino:1:10: fatal error: d:\Arduino\libraries\Arduino_AdvancedAnalog\src/Arduino_AdvancedAnalog.h: Permission denied
exit status 1
Compilation error: d:\Arduino\libraries\Arduino_AdvancedAnalog\src/Arduino_AdvancedAnalog.h: Permission denied
Eventually set the IDE as run as Administrator and problem now solved
Ohhh
I see, you have been experiencing this problem for years...
