Persist Data on Opta
Good morning everyone,
I am writing because I cannot persist data on Opta Finder Pro. From the documentation I found online I understood that it is possible to save variables persistently on the device. It would be convenient for me to save the wifi credentials (so a text representing the password would be sufficient).
It should be possible through the LittleFSManager.h library.
I tried this program:
#include "LittleFSManager.h"
    if (!initLittleFS()) return;
    String miavar = readVariable("miavar");
    if (miavar == "") {
        while (Serial.available() == 0);
        miavar = Serial.readStringUntil('\n');
        miavar.trim();
        saveVariable("miavar", miavar);
        NVIC_SystemReset();
    if (readVariable("miavar") != "") {
        Serial.println("password impostata");
        delay(5000);
The compilation does not give errors, but once started the device goes into protection (red LED blinking).
This microcontroller came to me by chance, I would like to play with it a bit, do you know if it is possible to persist data on the device?
The Arduino Opta Finder Pro uses the STM32H747XI microcontroller from STMicroelectronics.
Obviously I wouldn't want to use an external SD.
Hello maurogallo,
You can use flash memory, just read this tutorial.
I hope that is what you are looking for.
