(Persistence Of Vision) -- help
mensage post by CrossRoads
There is a way to create a timer based interrupt to perform things on a steady time time interval, ask in the Programming forum about that.
I would just use micros() and blink without delay timing myself.
void loop(){
currentTime = micros();
elapsedTme = currentTime - previousTime; // all time related items are unsigned long
if (elapsedTime >= duration){
previousTime = previousTime + duration; // set up for next display change
// do whatever gets done for updating the display, make sure it takes
// less time to complete than 'duration'
} // end time check
} // end loop
by Naruto
hello, perhaps they remember me, I still have not start this project.
my problem is to calculate the time to paint the entire wheel at a rate "constant."
I problado in different ways, but I can not do it.
you use this function?
interrupts ();
/ / Code ignition internal leds
noInterrupts ();
void setup () {
       attachInterrupt (0, rpm, FALLING);
 void rpm(){
                 interruptHit=true;
                 new_time=micros();
                Refresh = (  (( new_time - timeold)- 244841) /160);   //  244841=time it takes the paint arduino,--
        // 160=ray amount
                     //   Refresh = ( ( new_time - timeold) /160);
                 if(Refresh<=0){
                 Refresh=0;
                 timeold =  new_time;
		  void loop(){
     if( interruptHit ==true){
            for(uint8_t curPos=0; curPos<160;curPos++ ){
                      for(uint8_t i=0;i<34;i+=1){  //number of pixels
                           PixelColor(i,  ,  R,G,B  ) ;
         ShowsWS2803();
             refreshEnd=micros();
             while((micros() - refreshEnd)< Refresh   ) {;}
                           interruptHit =false;
else{
                      for(uint8_t i=0;i<nPixel;i++){
                                          PixelColor(i, 0,0,0) ;
                      loadWS2803();
}// end loop
