Persistence Of Vision  (POV) software
This looks really interesting. Can anyone get this to work? It doesn’t seem to work for me. There is no activity on pins 2.3.4.5.6 when checked with an oscilloscope. How does one troubleshoot the code? I am new at coding and just learning. I particularly don’t understand the line: void printLetter(int letter)
Does anyone have any other Arduino POV projects?
[ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533][ch65533]
persistence of vision typography with arduino
michael zoellner - march 2006
http://i.document.m05.de
connect anodes (+) of 5 leds to digital ports of the arduino board
and put 20-50 ohm resistors from the cathode (-) to ground.
the letters are lookup tables consisting arrays width the dot status in y rows.
// defining the alphabet
int _ = {0,0,0,0,0, 0,0,0,0,0, 0,0,0,0,0};
int A = {0,1,1,1,1, 1,0,1,0,0, 0,1,1,1,1};
int B = {1,1,1,1,1, 1,0,1,0,1, 0,1,0,1,0};
int C = {0,1,1,1,0, 1,0,0,0,1, 1,0,0,0,1};
int D = {1,1,1,1,1, 1,0,0,0,1, 0,1,1,1,0};
int E = {1,1,1,1,1, 1,0,1,0,1, 1,0,1,0,1};
int F = {1,1,1,1,1, 1,0,1,0,0, 1,0,1,0,0};
int G = {0,1,1,1,0, 1,0,1,0,1, 0,0,1,1,0};
int H = {1,1,1,1,1, 0,0,1,0,0, 1,1,1,1,1};
int I = {0,0,0,0,1, 1,0,1,1,1, 0,0,0,0,1};
int J = {1,0,0,0,0, 1,0,0,0,1, 1,1,1,1,1};
int K = {1,1,1,1,1, 0,0,1,0,0, 0,1,0,1,1};
int L = {1,1,1,1,1, 0,0,0,0,1, 0,0,0,0,1};
int M = {1,1,1,1,1, 0,1,1,0,0, 0,1,1,1,1};
int N = {1,1,1,1,1, 1,0,0,0,0, 0,1,1,1,1};
int O = {0,1,1,1,0, 1,0,0,0,1, 0,1,1,1,0};
int P = {1,1,1,1,1, 1,0,1,0,0, 0,1,0,0,0};
int Q = {0,1,1,1,1, 1,0,0,1,1, 0,1,1,1,1};
int R = {1,1,1,1,1, 1,0,1,0,0, 0,1,0,1,1};
int S = {0,1,0,0,1, 1,0,1,0,1, 1,0,0,1,0};
int T = {1,0,0,0,0, 1,1,1,1,1, 1,0,0,0,0};
int U = {1,1,1,1,1, 0,0,0,0,1, 1,1,1,1,1};
int V = {1,1,1,1,0, 0,0,0,0,1, 1,1,1,1,0};
int W = {1,1,1,1,0, 0,0,1,1,0, 1,1,1,1,0};
int X = {1,1,0,1,1, 0,0,1,0,0, 1,1,0,1,1};
int Y = {1,1,0,0,0, 0,0,1,0,0, 1,1,1,1,1};
int Z = {1,0,0,1,1, 1,0,1,0,1, 1,1,0,0,1};
int letterSpace;
int dotTime;
// setting the ports of the leds to OUTPUT
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
// defining the space between the letters (ms)
letterSpace = 6;
// defining the time dots appear (ms)
dotTime = 3;
int y;
// printing the first y row of the letter
for (y=0; y<5; y++)
digitalWrite(y+2, letter[y]);
delay(dotTime);
// printing the second y row of the letter
for (y=0; y<5; y++)
digitalWrite(y+2, letter[y+5]);
delay(dotTime);
// printing the third y row of the letter
for (y=0; y<5; y++)
digitalWrite(y+2, letter[y+10]);
delay(dotTime);
// printing the sspace between the letters
for (y=0; y<5; y++)
digitalWrite(y+2, 0);
delay(letterSpace);
// printing some letters
printLetter(N);
printLetter(E);
printLetter(R);
printLetter(D);
printLetter(S);
printLetter(_);
It works for me. I used a 220 ohm resistor on -each- LED. I can't say I can see the word it's supposed to display yet, but there's definitely something in there...I think it just needs to have the timing values adjusted.
Scratch that-- I can see the word pretty well now. You just have to wave it in front of your face like a raving lunatic, and then you'll see it. It will make a good tutorial for my prototyping classes...
PS: void printLetter() is a user function that spits out the proper LED values, and int letter[] is an array variable.
Thanks, Daniel, I will set it up again. I must have a mistake somewhere.
I'm not getting it working either.
I've actually noticed that with one of my programs, when I have a large amount of data, it doesn't run on my arduino. i drop the sizes down, and it works.
In fact, I have a very simple setup() and loop() which run fine on their own, but once i add all of the data structures, it fails...
AHA!
if you change all of the "int L[] = { ... }" to be "static int ... " it works. ie:
  static int _[] = {0,0,0,0,0, 0,0,0,0,0, 0,0,0,0,0};
  static int A[] = {0,1,1,1,1, 1,0,1,0,0, 0,1,1,1,1};
  static int B[] = {1,1,1,1,1, 1,0,1,0,1, 0,1,0,1,0};
  static int C[] = {0,1,1,1,0, 1,0,0,0,1, 1,0,0,0,1};
I just figure this out with one of my sketches (http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1165169485)
Happy coding, everyone! :D
You could save a lot of space by changing the arrays from “int” (2 bytes) to “char” (1 byte):
static char _ = {0,0,0,0,0, 0,0,0,0,0, 0,0,0,0,0};
// … etc …
You would not have to modify any of the rest of the code.
If you are more ambitious, you could replace each array with a single “int”, because each value in the array is just a bit (either 0 or 1). For example:
#define LETTER(a,b,c,d,e,f,g,h,i,j,k,l,m,n,o)
((a)<<14|(b)<<13|(c)<<12|(d)<<11|(e)<<10|
((f)<<9|(g)<<8|(h)<<7|(i)<<6|(j)<<5|
((k)<<4|(l)<<3|(m)<<2|(n)<<1|(o))
Note the backslashes at the end of the first 3 lines, which allow the macro definition to span lines.
static int _ = LETTER(0,0,0,0,0, 0,0,0,0,0, 0,0,0,0,0);
static int A = LETTER(0,1,1,1,1, 1,0,1,0,0, 0,1,1,1,1);
// … etc …
Then, to access a particular bit within a letter, instead of accessing array, you would retrieve a bit using the following macro:
#define GETBIT(variable,position) (((variable) >> (15-position)) & 1)
For example, GETBIT(A,0) would access the leftmost bit in the variable A.
While this is a bit of work, it would shrink your data size by a factor of 16. But of course this matters only if you intend to make the rest of the code more complex.
I was having trouble getting it to work as well. I checked the signals with the an oscilliscope and nothing.
After scratching my head I finally figured out that the problem (for me) was that the IDE chose the wrong chip ATmega8 versus ATmega168
