Hi Newbie here, ...
Can anyone point to a solution to the following Error msg? I am at my wits end here. I just have not been able to solve this.
Arduino: 1.8.13 (Windows 7), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Vid\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Vid\AppData\Local\Temp\arduino_build_976500 -warnings=none -build-cache C:\Users\Vid\AppData\Local\Temp\arduino_cache_433155 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Vid\Documents\Arduino\libraries\AOA_Standalone\AOA_Standalone.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Vid\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\Vid\AppData\Local\Temp\arduino_build_976500 -warnings=none -build-cache C:\Users\Vid\AppData\Local\Temp\arduino_cache_433155 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Vid\Documents\Arduino\libraries\AOA_Standalone\AOA_Standalone.ino
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\sketch\AOA_Standalone.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\sketch\AOA_Standalone.ino.cpp" -o "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\sketch\AOA_Standalone.ino.cpp" -o "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\sketch\AOA_Standalone.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\wiring_pulse.S.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\hooks.c.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\wiring_analog.c.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\wiring.c.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\wiring_digital.c.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\wiring_shift.c.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\WInterrupts.c.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\WMath.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\WString.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\abi.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\new.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\CDC.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\USBCore.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\main.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\Print.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\Stream.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\Tone.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\core\core.a
Archiving built core (caching) in: C:\Users\Vid\AppData\Local\Temp\arduino_cache_433155\core\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500/AOA_Standalone.ino.elf" "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500\sketch\AOA_Standalone.ino.cpp.o" "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500/core\core.a" "-LC:\Users\Vid\AppData\Local\Temp\arduino_build_976500" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500/AOA_Standalone.ino.elf" "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500/AOA_Standalone.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500/AOA_Standalone.ino.elf" "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500/AOA_Standalone.ino.hex"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-size" -A "C:\Users\Vid\AppData\Local\Temp\arduino_build_976500/AOA_Standalone.ino.elf"
Sketch uses 6458 bytes (21%) of program storage space. Maximum is 30720 bytes.
Global variables use 1520 bytes (74%) of dynamic memory, leaving 528 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xbe
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Invalid library found in C:\Users\Vid\Documents\Arduino\libraries\AOA_Standalone: no headers files (.h) found in C:\Users\Vid\Documents\Arduino\libraries\AOA_Standalone
