Mein Code zum Beschreibes des Tags
* Write personal data of a MIFARE RFID card using a RFID-RC522 reader
* Uses MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
* MFRC522 Arduino Arduino Arduino Arduino Arduino
* Reader/PCD Uno/101 Mega Nano v3 Leonardo/Micro Pro Micro
* Signal Pin Pin Pin Pin Pin Pin
* RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
* SPI SS SDA(SS) 10 53 D10 10 10
* SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
* SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
* SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
* Hardware required:
* Arduino
* PCD (Proximity Coupling Device): NXP MFRC522 Contactless Reader IC
* PICC (Proximity Integrated Circuit Card): A card or tag using the ISO 14443A interface, eg Mifare or NTAG203.
* The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println(F("Write personal data on a MIFARE PICC "));
// Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
Serial.print(F("Card UID:")); //Dump UID
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
Serial.print(F(" PICC type: ")); // Dump PICC type
MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
Serial.println(mfrc522.PICC_GetTypeName(piccType));
byte buffer[34];
byte block;
MFRC522::StatusCode status;
byte len;
Serial.setTimeout(20000L) ; // wait until 20 seconds for input from serial
// Ask personal data: Family name
Serial.println(F("Titel name, ending with #"));
len = Serial.readBytesUntil('#', (char *) buffer, 30) ; // read family name from serial
for (byte i = len; i < 30; i++) buffer[i] = ' '; // pad with spaces
block = 1;
//Serial.println(F("Authenticating using key A..."));
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK) {
Serial.print(F("PCD_Authenticate() failed: "));
Serial.println(mfrc522.GetStatusCodeName(status));
return;
else Serial.println(F("PCD_Authenticate() success: "));
// Write block
status = mfrc522.MIFARE_Write(block, buffer, 16);
Serial.print(F("MIFARE_Write() failed: "));
return;
else Serial.println(F("MIFARE_Write() success: "));
block = 2;
return;
// Write block
status = mfrc522.MIFARE_Write(block, &buffer[16], 16);
return;
// Ask personal data: First name
Serial.println(F("Type Signatur, ending with #"));
len = Serial.readBytesUntil('#', (char *) buffer, 20) ; // read first name from serial
for (byte i = len; i < 20; i++) buffer[i] = ' '; // pad with spaces
block = 4;
return;
// Write block
return;
Serial.println(F("Type Inventarnummer, ending with #"));
block = 5;
return;
// Write block
return;
Serial.println(" ");
mfrc522.PICC_HaltA(); // Halt PICC
mfrc522.PCD_StopCrypto1(); // Stop encryption on PCD
Mein Code zum Auslesen des Tags
* Initial Author: ryand1011 (https://github.com/ryand1011)
* Reads data written by a program such as "rfid_write_personal_data.ino"
* See: https://github.com/miguelbalboa/rfid/tree/master/examples/rfid_write_personal_data
* Uses MIFARE RFID card using RFID-RC522 reader
#include <SPI.h>
Serial.println(F("Read personal data on a MIFARE PICC:")); //shows in serial that it is ready to read
//some variables we need
byte block;
byte len;
return;
return;
Serial.println(F("**Card Detected:**"));
mfrc522.PICC_DumpDetailsToSerial(&(mfrc522.uid)); //dump some details about the card
//mfrc522.PICC_DumpToSerial(&(mfrc522.uid)); //uncomment this to see all blocks in hex
Serial.print(F("Buchtitel: "));
byte buffer1[18];
block = 1;
len = 18;
//------------------------------------------- GET Buchtitel
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 1, &key, &(mfrc522.uid)); //line 834 of MFRC522.cpp file
Serial.print(F("Authentication failed: "));
return;
status = mfrc522.MIFARE_Read(block, buffer1, &len);
Serial.print(F("Reading failed: "));
return;
//PRINT Buchtitel
for (uint8_t i = 0; i < 16; i++)
if (buffer1[i] != 32)
Serial.write(buffer1[i]);
Serial.print("Signatur:");
//---------------------------------------- GET Signatur
byte buffer2[18];
block = 4;
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 4, &key, &(mfrc522.uid)); //line 834
return;
status = mfrc522.MIFARE_Read(block, buffer2, &len);
return;
//PRINT Signatur
for (uint8_t i = 0; i < 16; i++) {
Serial.write(buffer2[i] );
Serial.print("Inventarnummer:");
//---------------- GET BLOCK 5
byte buffer3[18];
block = 5;
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 5, &key, &(mfrc522.uid)); //line 834
return;
status = mfrc522.MIFARE_Read(block, buffer3, &len);
return;
//PRINT Inventarnummer
Serial.write(buffer3[i] );
Serial.println(F("\n**End Reading**\n"));
delay(1000); //change value if you want to read cards faster
