Hej hej,
I would like to write RFID tags for a project with the RFID-RC522 and read them later.
It is about simulating chaotic storage.
And so that the whole thing is a little "spiced up", I want to describe my RFID tag, namely with title, inventory number and signature.
Now I have two problems.
I want to write my RFID tag with title, inventory number and signature. So far so good the write_personal_data code has been rebuilt. Two "entries" were already "given" in block 1 and 4, if I then write something in block 5 (for example the word Inventarnummer) and then want to read it with read_personal_data, then I get instead of "inventory number" a number displayed, which has nothing to do with it.
It doesn't matter in which order the blocks are displayed, block 5 always shows the number. No matter what was written into the field. Did I make a mistake or does it just not work the way I thought it would?
Problem two is that I want to read the written tags with two readers. So effectively of course only with one, but I want to know so to speak which "book" is in the range of which reader. The ReadUidMultiReader code runs without any problems, but I'm not sure how to read the data I've written to the tag in this installation. Is this possible at all?
Many thanks in advance
Write_Data
* Write personal data of a MIFARE RFID card using a RFID-RC522 reader
* Uses MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
* MFRC522 Arduino Arduino Arduino Arduino Arduino
* Reader/PCD Uno/101 Mega Nano v3 Leonardo/Micro Pro Micro
* Signal Pin Pin Pin Pin Pin Pin
* RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
* SPI SS SDA(SS) 10 53 D10 10 10
* SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
* SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
* SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
* Hardware required:
* Arduino
* PCD (Proximity Coupling Device): NXP MFRC522 Contactless Reader IC
* PICC (Proximity Integrated Circuit Card): A card or tag using the ISO 14443A interface, eg Mifare or NTAG203.
* The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println(F("Write personal data on a MIFARE PICC "));
// Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
Serial.print(F("Card UID:")); //Dump UID
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
Serial.print(F(" PICC type: ")); // Dump PICC type
MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
Serial.println(mfrc522.PICC_GetTypeName(piccType));
byte buffer[34];
byte block;
MFRC522::StatusCode status;
byte len;
Serial.setTimeout(20000L) ; // wait until 20 seconds for input from serial
// Ask personal data: Family name
Serial.println(F("Titel name, ending with #"));
len = Serial.readBytesUntil('#', (char *) buffer, 30) ; // read family name from serial
for (byte i = len; i < 30; i++) buffer[i] = ' '; // pad with spaces
block = 1;
//Serial.println(F("Authenticating using key A..."));
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK) {
Serial.print(F("PCD_Authenticate() failed: "));
Serial.println(mfrc522.GetStatusCodeName(status));
return;
else Serial.println(F("PCD_Authenticate() success: "));
// Write block
status = mfrc522.MIFARE_Write(block, buffer, 16);
Serial.print(F("MIFARE_Write() failed: "));
return;
else Serial.println(F("MIFARE_Write() success: "));
block = 2;
return;
// Write block
status = mfrc522.MIFARE_Write(block, &buffer[16], 16);
return;
// Ask personal data: First name
Serial.println(F("Type Signatur, ending with #"));
len = Serial.readBytesUntil('#', (char *) buffer, 20) ; // read first name from serial
for (byte i = len; i < 20; i++) buffer[i] = ' '; // pad with spaces
block = 4;
return;
// Write block
return;
Serial.println(F("Type Inventarnummer, ending with #"));
block = 5;
return;
// Write block
return;
Serial.println(" ");
mfrc522.PICC_HaltA(); // Halt PICC
mfrc522.PCD_StopCrypto1(); // Stop encryption on PCD
Read_Data
* Initial Author: ryand1011 (https://github.com/ryand1011)
* Reads data written by a program such as "rfid_write_personal_data.ino"
* See: https://github.com/miguelbalboa/rfid/tree/master/examples/rfid_write_personal_data
* Uses MIFARE RFID card using RFID-RC522 reader
#include <SPI.h>
Serial.println(F("Read personal data on a MIFARE PICC:")); //shows in serial that it is ready to read
//some variables we need
byte block;
byte len;
return;
return;
Serial.println(F("**Card Detected:**"));
mfrc522.PICC_DumpDetailsToSerial(&(mfrc522.uid)); //dump some details about the card
//mfrc522.PICC_DumpToSerial(&(mfrc522.uid)); //uncomment this to see all blocks in hex
Serial.print(F("Buchtitel: "));
byte buffer1[18];
block = 1;
len = 18;
//------------------------------------------- GET Buchtitel
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 1, &key, &(mfrc522.uid)); //line 834 of MFRC522.cpp file
Serial.print(F("Authentication failed: "));
return;
status = mfrc522.MIFARE_Read(block, buffer1, &len);
Serial.print(F("Reading failed: "));
return;
//PRINT Buchtitel
for (uint8_t i = 0; i < 16; i++)
if (buffer1[i] != 32)
Serial.write(buffer1[i]);
Serial.print("Signatur:");
//---------------------------------------- GET Signatur
byte buffer2[18];
block = 4;
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 4, &key, &(mfrc522.uid)); //line 834
return;
status = mfrc522.MIFARE_Read(block, buffer2, &len);
return;
//PRINT Signatur
for (uint8_t i = 0; i < 16; i++) {
Serial.write(buffer2[i] );
Serial.print("Inventarnummer:");
//---------------- GET BLOCK 5
byte buffer3[18];
block = 5;
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 5, &key, &(mfrc522.uid)); //line 834
return;
status = mfrc522.MIFARE_Read(block, buffer3, &len);
return;
//PRINT Inventarnummer
Serial.write(buffer3[i] );
Serial.println(F("\n**End Reading**\n"));
delay(1000); //change value if you want to read cards faster
