Many ways. It would help if you described what other responsibilities the processor will have, and how and where from the current value of the PFM is coming.
And pretty much anything else you can share.
Just synthesizing the PFM at such low frequencies is relatively straight forward. It's the context that will (or won't) colmpicate things.
in this code I wrote, the "ledcInit()" function allows the
frequency varies from 1 Hz to 40 MHz, just vary the value of the "oscillator" variable and call the routine only when modifying the frequency value.
#include "driver/ledc.h"
#define LEDC_HS_CH0_CHANNEL LEDC_CHANNEL_0 // LEDC no canal 0
#define LEDC_HS_CH0_GPIO GPIO_NUM_25 // Saida do ledc gerador de pulsos
uint32_t oscilator = 2; // Frequencia em Hz
uint32_t mDuty = 0; // Valor calculado do duty
uint32_t resolution = 0; // Valor calculado da resolucao
Serial.println("Hello, ESP32!");
ledcInit ();
delay(10); // this speeds up the simulation
void ledcInit ()
resolution = log((80000000 / oscilator) + 1) / log(2); // Calculo da resolucao para ledc
if (resolution > 20) resolution = 20; // Maxima resolucao é 20
// Serial.println(resolution); // Print
mDuty = (pow(2, resolution)) / 2; // Calculo do duty para ledc 50%
//Serial.println(mDuty); // Print
ledc_timer_config_t ledc_timer = {}; // Instancia a configuracao do timer do ledc
// ledc_timer.duty_resolution = resolucao; // Configura resolucao
ledc_timer.duty_resolution = (ledc_timer_bit_t) + resolution; // Configura resolucao
ledc_timer.freq_hz = oscilator; // Frequencia de oscilacao
ledc_timer.speed_mode = LEDC_HIGH_SPEED_MODE; // Mode de operacao em high speed
ledc_timer.timer_num = LEDC_TIMER_0; // Usar timer0 do ledc
ledc_timer_config(&ledc_timer); // Configurar o timer do ledc
ledc_channel_config_t ledc_channel = {}; // Instancia a configuracao canal do ledc
ledc_channel.channel = LEDC_HS_CH0_CHANNEL; // Configura canal0
ledc_channel.duty = mDuty; // Valor calculado do duty em %
ledc_channel.gpio_num = LEDC_HS_CH0_GPIO; // Saida no GPIO defino no inicio
ledc_channel.intr_type = LEDC_INTR_DISABLE; // Desabilita interrupt de ledc
ledc_channel.speed_mode = LEDC_HIGH_SPEED_MODE; // Mode de operacao do canal em high speed
ledc_channel.timer_sel = LEDC_TIMER_0; // Usar timer0 do ledc
ledc_channel_config(&ledc_channel); // Configurar o canal do ledc
Given the very low maximum frequency, I would think a bit-banged output triggered by a timer interrupt might well be the way to go. But it depends on the required precision, which, like other key specifications, is currently completely unspecified.
@anon57585045, actually you are the one in error here.
PWM vs. PFM
PWM is not the only technique for regulating the output of a switching converter. Instead of modifying the duty cycle of a fixed-frequency square wave to regulate the output of a power supply, it is also possible to use a constant duty cycle and then modulate the square wave’s frequency (PFM) to achieve regulation. DC/DC voltage converters equipped with constant-on-time or constant-off-time control are typical examples of PFM architecture.
I believe it is the article that is in error. By "constant duty cycle" they undoubtedly meant "constant pulse width".
As far as sticking to the topic, we are discussing PFM, right? You haven't mentioned at all what this pulse train will be driving. If it results in an integration of the pulses by means of low pass filtering, your interpretation will produce a constant, invariable signal.
If you don't believe me, look at fig. 1 in the article you linked. It illustrates PFM. All the pulses are a constant length, it is not a constant duty cycle.
I don't just post stuff without any thought. If "the topic" is actually crucially related to some circuit you are driving, then you need to post all the information about that.
I agree, and think it is simply a typo, as the very next sentence makes clear.
In that case Wikipedia is also wrong because it also states a fixed 50% duty cycle is also possible.
From Wikipedia:
PFM mode operation allows the switching frequency to be reduced and for a control method that prevents the inductor current from dropping below zero during light loads. Rather than applying square pulses of varying widths to the inductor, square pulse trains with a fixed 50% duty cycle are used to charge the inductor to a predefined current limit then discharge the inductor current to, but not below, zero. The frequency of these pulse trains is then varied to produce the desired output voltage with the aid of the output filter capacitor.
Or, perhaps, both Wikipedia and Digikey, and I, are correct, fixed duty cycle is a PMF mode ...
The Wikipedia article describes a reasonable pulse train to control current through a conductor, but is obviously not the sort of PFM discussed in the DC/DC switching article with the unfortunate and confusing typo.
You are most welcome to generate a 50% duty cycle, variable frequency signal, so just get on with your project.
How about opening a new topic on the conceptual discussion of the term PFM ?
And in this topic focus on meeting your need.
I understand that your need is a 50% fixed duty pulse train with the possibility of varying the frequency.
Right?
