Hello all
I bought this pH board but I can´t find the library nor the code.
Can you please help me ?
thanks in advance
Miza
Hello all
thanks in advance
Miza
IF you have a link to a data sheet or something similar (in English) it might help.
Paul
From the look of it this are most likely analog outputs.
Stick that pH probe in pH=7 and pH=4 (or even pH=10) buffers and measure the output. Then you got the calibration for your probe.
The temperature probe is probably a thermistor. Without knowing the parameters of the thing it's hard to use.
For added fun: the thermistor is ratiometric, the pH probe is absolute. The only way to get good readings is to make sure your 5V Vcc is dead stable.
