#include <Arduino.h>
#include "DFRobot_LCD.h"
#include <Wire.h>
#include "WiFi.h"
#include "ThingSpeak.h"
**// ThingSpeak----------------------------------------------------------------------/**
**WiFiClient client;**
**char ssid[] = "ASUS nanosun-123";**
**char pass[] = "201312279c"; **
**int status = WL_IDLE_STATUS;**
**unsigned long myChannelNumber = 1967185;**
**const char * myWriteAPIKey = "A3Y9LSEOI6ETE19T";**
// DO SENSOR-----------------------------------------------------------------/
#define DO_PIN A1
#define VREF 5000 // VREF(mv)
#define ADC_RES 1024 //ADC Resolution/
#define SINGLE_POINT_CALIBRATION 0
#define READ_TEMP (25)
#define CAL1_V (8354) //mv CHANGE AFTER CALIBRATION
#define CAL1_T (25) //℃
const uint16_t DO_Table[41] = {
14460, 14220, 13820, 13440, 13090, 12740, 12420, 12110, 11810, 11530,
11260, 11010, 10770, 10530, 10300, 10080, 9860, 9660, 9460, 9270,
9080, 8900, 8730, 8570, 8410, 8250, 8110, 7960, 7820, 7690,
7560, 7430, 7300, 7180, 7070, 6950, 6840, 6730, 6630, 6530, 6410};
uint8_t Temperaturet;
uint16_t ADC_Raw;
uint16_t ADC_Voltage;
uint16_t DO;
int16_t readDO(uint32_t voltage_mv, uint8_t temperature_c)
#if SINGLE_POINT_CALIBRATION == 00
uint16_t V_saturation = (uint32_t)CAL1_V + (uint32_t)35 * temperature_c - (uint32_t)CAL1_T * 35;
return (voltage_mv * DO_Table[temperature_c] / V_saturation);
#else
uint16_t V_saturation = (int16_t)((int8_t)temperature_c - CAL2_T) * ((uint16_t)CAL1_V - CAL2_V) / ((uint8_t)CAL1_T - CAL2_T) + CAL2_V;
#endif
// pH SENSOR---------------------------------------/
DFRobot_LCD lcd(16, 2); //16 characters and 2 lines of show
#**define PH_PIN 25 **
**float voltage,phvalue,temperature = 25;**
**float acidVoltage = 2000; //buffer solution at 4.o **
**float neutralVoltage = 1390; //buffer solution at 7.o **
**const int Sensor_MINvalue1 = 6.5; // +-0.5 from ph 4.0**
**const int Sensor_MAXvalue1 = 7.5;**
// LCD Begin //
lcd.init();
lcd.setCursor(4,0);
lcd.print("Welcome");
lcd.clear();
lcd.setCursor(3,0);
lcd.print("Reading ");
lcd.setCursor(3,1);
lcd.print("pH & DO");
lcd.clear();
lcd.setCursor(3,0);
lcd.print("Please Wait");
lcd.clear();
**//ThingSpeak----------------------------------------------------------//**
** delay(100);**
** float P = phvalue;**
** float D = (readDO(ADC_Voltage, Temperaturet)/1000);**
** ThingSpeak.setField(1,P);**
** ThingSpeak.setField(2,D); **
** ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);**
**//pH SENSOR--------------------------------------//**
** static unsigned long timepoint = millis();**
** if(millis()-timepoint>1000U){**
** timepoint = millis();// timepoint = read temperature **
** voltage = analogRead (PH_PIN)/4095.0*3300; **
** float slope = (7.0-4.0)/((neutralVoltage-1500)/30 - (acidVoltage-1500)/3.0);**
** float intercept = 7.0 - slope*(neutralVoltage-1500)/3.0;**
** phvalue = slope*(voltage-1500)/3.0 + intercept; // y=k*x + b [formula]**
if( phvalue < Sensor_MAXvalue1 && phvalue > Sensor_MINvalue1 ){
Serial.print("Voltage:");
Serial.print(voltage,1);
Serial.print("PH:");
Serial.println(phvalue,2);
//LCD setting 16x2
lcd.setCursor(0,0);
lcd.print("PH: ");
lcd.print(phvalue,2);
lcd.setCursor(0,1);
lcd.print("Volt: ");
lcd.print(voltage/1000,2);}
else {
lcd.init();
lcd.setCursor(0,0);
lcd.print("DOSING REQUIRED");
lcd.clear(); }
Temperaturet = (uint8_t)READ_TEMP;
ADC_Raw = analogRead(DO_PIN);
ADC_Voltage = uint32_t(VREF) * ADC_Raw / ADC_RES;
Serial.print("Temperaturet:\t" + String(Temperaturet) + "\t");
Serial.print("ADC RAW:\t" + String(ADC_Raw) + "\t");
Serial.print("ADC Voltage:\t" + String(ADC_Voltage) + "\t");
Serial.println("DO:\t" + String(readDO(ADC_Voltage, Temperaturet)) + "\t");
//LCD setting 16x2
lcd.setCursor(9,0);
lcd.print((readDO(ADC_Voltage, Temperaturet))/1000);
lcd.print("mg/L");
delay(5000);
lcd.clear();
return;
I have posted a similar code before but about a different question, as of now. i have fixed my thingSpeak, Dissolved Oxygen sensor.
however, upon including the thingspeak code into t it causes my Ph sensor to misread the ph from 7ph it would read 15.16047ph I believe it's not the code that's having the issue but the formula [ calculation ] , is there a way for me to change it so that it would read back 7ph instead. the bolded code is my ph and thins
