Ph sensor connect to arduino
Why when connect ph with arduino give me wrong values?
What correct code
Please read the forum guidelines.
Tell us about your specific sensor, your wiring and your current code...
And the results you get...
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <SimpleTimer.h>
SimpleTimer timer;
float calibration_value = 21.34 - 0.7;
int phval = 0;
unsigned long int avgval;
int buffer_arr[10],temp;
float ph_act;
// for the OLED display
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Wire.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.setTextColor(WHITE);
timer.setInterval(500L, display_pHValue);
timer.run(); // Initiates SimpleTimer
for(int i=0;i<10;i++)
buffer_arr[i]=analogRead(A0);
delay(30);
for(int i=0;i<9;i++)
for(int j=i+1;j<10;j++)
if(buffer_arr[i]>buffer_arr[j])
temp=buffer_arr[i];
buffer_arr[i]=buffer_arr[j];
buffer_arr[j]=temp;
avgval=0;
for(int i=2;i<8;i++)
avgval+=buffer_arr[i];
float volt=(float)avgval*5.0/1024/6;
ph_act = -5.70 * volt + calibration_value;
Serial.println("pH Val: ");
Serial.print(ph_act);
void display_pHValue()
// display on Oled display
// Oled display
display.setTextSize(2);
display.setCursor(0,0); // column row
display.print("pH:");
display.setCursor(55, 0);
display.print(ph_act);
display.setCursor(0,30);
display.print("EC:");
display.setCursor(60, 30);
display.print(345);
display.setCursor(95, 50);
display.display();
This the code which I use it
The ph value showing
0.7and it not change
Please take a few minutes and read the forum guidelines at How to get the best out of this forum.
Please use code tags.
Give us a link to the datasheet for your sensor, or at least a link to the page where you bought it from. No one here can read minds: we don't know what sensor you're using until you tell us.
