ph sensor fluctuates from 0 to 800 in yogurt
Hello amazing people I m damn ashamed to share a simple but ridiculous issue of my pH sensor..... I m usin NodeMCU and am tryna read voltage at first..........when left un toucher it fluctuates as well as in water or in any thing......here is ma code (Behold! Thy lord Casted a Big and long Code onto Thee)
    Serial.println(analogRead(A0));
heres the sensor https://www.google.com/search?q=ph+sensor+not+working+arduino&rlz=1C1CHZL_enIN780IN780&source=lnms&tbm=isch&sa=X&sqi=2&ved=0ahUKEwjCoZvjpLnfAhVak3AKHZ0UAlkQ_AUIDygC&biw=1242&bih=569#imgrc=GVnLQp1NXHASJM:
Please post a link to the actual sensor, not to a google search.
The symptoms you report suggest a floating input.
Thanks jremington for your reply…even i thought these are floating valued…so i wrote A0 to high,then values were different but still fluctuating
Writing a HIGH to A0 turns on the pullup resistor, which will lead to wrong readings in any case.
To avoid a floating input, connect the pH meter and Arduino grounds. If you have already done that, you probably have a faulty connection.
Post a hand-drawn (not Fritzing) diagram showing all the wiring.
