pH sensor on UNO VS MKR 1010 sensor reading problem
Hi!
im trying to use a Gravity: Analog pH Sensor / Meter Pro Kit For Arduino.
when i connect it to a arduino UNO i get good results with the example code given on DF Robot
but when i connect the sensor to a Arduino MKR 1010 i get values that are too high.
The pins are connected exactly the same as shown in the wiring diagram above. both use 5V, GND and A0 as the analog pin.
does anybody know what the problem could be?
Serial monitor readout from MKR wifi 1010
Voltage:3.17 pH value: 11.10
Serial monitor readout from Uno
Voltage:2.06 pH value: 7.22
Code used:
 # This sample code is used to test the pH meter V1.0.
 # Editor : YouYou
 # Ver    : 1.0
 # Product: analog pH meter
 # SKU    : SEN0161
#define SensorPin A1            //pH meter Analog output to Arduino Analog Input 0
#define Offset 0.00            //deviation compensate
#define LED 13
#define samplingInterval 20
#define printInterval 800
#define ArrayLenth  40    //times of collection
int pHArray[ArrayLenth];   //Store the average value of the sensor feedback
int pHArrayIndex=0;
void setup(void)
  pinMode(LED,OUTPUT);
  Serial.println("pH meter experiment!");    //Test the serial monitor
void loop(void)
  static unsigned long samplingTime = millis();
  static unsigned long printTime = millis();
  static float pHValue,voltage;
  if(millis()-samplingTime > samplingInterval)
      pHArray[pHArrayIndex++]=analogRead(SensorPin);
      if(pHArrayIndex==ArrayLenth)pHArrayIndex=0;
      voltage = avergearray(pHArray, ArrayLenth)*5.0/1024;
      pHValue = 3.5*voltage+Offset;
      samplingTime=millis();
  if(millis() - printTime > printInterval)   //Every 800 milliseconds, print a numerical, convert the state of the LED indicator
    Serial.print("Voltage:");
        Serial.print(voltage,2);
        Serial.print("    pH value: ");
    Serial.println(pHValue,2);
        digitalWrite(LED,digitalRead(LED)^1);
        printTime=millis();
double avergearray(int* arr, int number){
  int i;
  int max,min;
  double avg;
  long amount=0;
  if(number<=0){
    Serial.println("Error number for the array to avraging!/n");
    return 0;
  if(number<5){   //less than 5, calculated directly statistics
    for(i=0;i<number;i++){
      amount+=arr[i];
    avg = amount/number;
    return avg;
  }else{
    if(arr[0]<arr[1]){
      min = arr[0];max=arr[1];
    else{
      min=arr[1];max=arr[0];
    for(i=2;i<number;i++){
      if(arr[i]<min){
        amount+=min;        //arr<min
        min=arr[i];
      }else {
        if(arr[i]>max){
          amount+=max;    //arr>max
          max=arr[i];
        }else{
          amount+=arr[i]; //min<=arr<=max
      }//if
    }//for
    avg = (double)amount/(number-2);
  }//if
  return avg;
but the analog pin of the MKR reads range 0 to 3.3 V and on Uno 0 to 5 V.
you are right! i changed:
to
voltage = avergearray(pHArray, ArrayLenth)*3.3/1024;
an now i get the correct values :smiley:
