PH Sensor
I am using Liquid PH0-14 ph sensor in my project but i get ph values like 50971 in adafruit io. please help me. this is my arduino code.
uint32_t samplingTime = millis();
uint32_t printTime = millis();
uint32_t pHValue,voltage;
if(millis()-samplingTime > samplingInterval)
pHArray[pHArrayIndex++]=analogRead(SensorPin);
if(pHArrayIndex==ArrayLenth)pHArrayIndex=0;
voltage = avergearray(pHArray, ArrayLenth)5.0/1024;
pHValue = 3.5
voltage+Offset;
samplingTime= millis();
if(millis() - printTime > printInterval) //Every 800 milliseconds, print a numerical, convert the state of the LED indicator
Serial.print("Voltage:");
Serial.println(voltage);
Serial.print("pH value: ");
Serial.println(pHValue);
digitalWrite(LED,digitalRead(LED)^1);
printTime=millis();
I'm not experienced with adafruit.io, but the code you posted doesn't seem to have anything to do with it.
I see you are printing the pH to Serial. Are you seeing the expected pH value printed in the Serial Monitor?
Please post your full sketch.
If possible, you should always post code directly in the forum thread as text using code tags:
  • Do an Auto Format (Tools > Auto Format in the Arduino IDE or Ctrl + B in the Arduino Web Editor) on your code. This will make it easier for you to spot bugs and make it easier for us to read.
  • In the Arduino IDE or Arduino Web Editor, click on the window that contains your sketch code.
  • Press "Ctrl + A". This will select all the text.
  • Press "Ctrl + C". This will copy the selected text to the clipboard.
  • In a forum reply here, click the "Reply" button.
  • click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the sketch between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
  • Repeat the above process if your sketch has multiple tabs.
This will make it easy for anyone to look at it, which will increase the likelihood of you getting help.
If the sketch is longer than the 9000 characters maximum allowed by the forum, then it's OK to add it as an attachment. After clicking the "Reply" button, you will see an "Attachments and other settings" link.
When your code requires a library that's not included with the Arduino IDE please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
you declare 'voltage' as 'uint32_t' but you are doing 'float' calculation here:
voltage = avergearray(pHArray, ArrayLenth)*5.0/1024;
same with 'pHValue'
try your code again declaring them as 'float' instead and see if you get sensible results.
hope that helps
