I try to display the pH value of my water aquarium in my home automation application: "Domoticz".
I already use MySensors probes which communicate with Domoticz via a radio chip.
There is an example code on MySensors but I do not know programming:
* The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
* Copyright (C) 2013-2019 Sensnology AB
* Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* REVISION HISTORY
* Version 1.0 - mboyer85
* DESCRIPTION
* Example sketch showing how to send PH readings back to the controller
// Enable debug prints to serial monitor
//#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_RF24
//#define MY_RADIO_NRF5_ESB
//#define MY_RADIO_RFM69
//#define MY_RADIO_RFM95
#include <MySensors.h>
#define COMPARE_PH 1 // Send PH only if changed? 1 = Yes 0 = No
uint32_t SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
float lastPH;
bool receivedConfig = false;
bool metric = true;
// Initialize PH message
MyMessage msg(0, V_PH);
//Setup your PH sensor here (I2C,Serial,Phidget...)
float getPH()
//query your PH sensor here (I2C,Serial,Phidget...)
float dummy = 7;
return dummy;
void presentation()
// Send the sketch version information to the gateway and Controller
sendSketchInfo("PH Sensor", "1.1");
present(0, S_WATER_QUALITY);
float ph = getPH();
#if COMPARE_PH == 1
if (lastPH != ph) {
#endif
// Send in the new PH value
send(msg.set(ph, 1));
// Save new PH value for next compare
lastPH = ph;
#if COMPARE_PH == 1
#endif
sleep(SLEEP_TIME);
I also found an interesting article but which does not communicate with domoticz : pH Arduino
If you do not know programing you will either have to get lucky find what you want, have a friend write it for you, pay somebody to write it, go online and learn programming or abandon it. Start by just getting the sensor to work then expand from there.
I am sorry but there is no one simple answer to your question. It appears you have read something that sounds good and picked up a few terms without any understanding of what each part of the equation is. Try breaking it down part by part and do some online tutorials on that and ask questions to help clarify what you have learned. As far as getting a specialist, most of us are hobbyist, and some professionals doing our best to help. We are all over the world, not in one big thinktank.
