Phantom 2 ESC and motor
Hello, I have recently taken apart my Phantom 2 drone and have specifically taken out the ESC and attached the brushless motor.
I will have Pics below
My question is how would I get this to run as one unit, without the flight controller? I notice that there is a (V) and (G)voltage and ground, could I just feed the V and G with a PWM signal from let's say an Arduino and could it be done without a microcontroller? Let's say a 555 timer with POT?
Or
There is also an orange and brown 4 pin JST connector which actually connects to the flight controller to where it says motor 4, so then if that the case how would I power that?
There is on the bottom of the ESC, 3 RGB LEDs that let you know the status of the aircraft.
Also in below is link to schematic to The ESC.
https://www.drohnen-forum.de/index.php/Attachment/5374-Schematic-WM-301-BLDC-V2-pdf/
Thanks
I'd restore the original state, and measure the voltages and control signals prior to decomposition.
