Hi folks, so I have an arduino uno that has a CC3000 Wifi Shield and a CN-06 Ublox Neo 6M GPS hooked up to it. I've managed to run some code to get the Wifi Sheild to behave properly by itself and I've also written some code that gets the GPS to function and spit out lat's long's etc.
My dilemma is when I try and combine the two codes and then Arduino gets all pissy with me. Here's the code:
Please excuse my messy commenting etc.
//Libraries
#include <SPI.h>
#include <string.h>
#include <Adafruit_CC3000.h>
#include <Adafruit_CC3000_Server.h>
#include <ccspi.h>
#include "utility/debug.h"
#include <stdlib.h>
#include <SoftwareSerial.h>
//Set Harware Configuration Pins etc.
SoftwareSerial gps_comms(6, 7); //Two pins that were free and not used for SPI commms
#define ADAFRUIT_CC3000_IRQ 3 // Must be an interrupt pin!
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIVIDER);
//Define GPS Parameters
const int data_size = 80;
char data[data_size];
int latitude = 0;
int longitude = 0;
char length = 0;
//char field[20];
//Define wifi parameters
#define WLAN_SSID "MagelliumLtd"
#define WLAN_PASS "blablabla"
#define WLAN_SECURITY WLAN_SEC_WPA2
//Xively Parameters
#define WEBSITE "api.xively.com"
#define API_key "thekey"
#define feedID "lol"
uint32_t ip = 0;
//Initialise GPS
gps_comms.begin(9600);
//Initialize CC3000
Serial.println(F("\nInitializing..."));
if (!cc3000.begin()) {
Serial.println(F("Couldn't begin()! Sort your life out!!!"));
while(1);
void loop(void) {
static int i = 0;
if (gps_comms.available()) {
char ch = gps_comms.read();
if (ch != '\n' && i < data_size) {
data[i] = ch;
i++;
else {
data[i] = '\0';
i = 0;
displayGPS();
getField();
//Connect to WiFi network
cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
Serial.println(F("Connected!"));
/*Wait for DHCP to complete */
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP()) {
delay(100);
//Get the website IP and Print it
ip = 0;
Serial.print(WEBSITE); Serial.print(F(" -> "));
while (ip == 0) {
if (!cc3000.getHostByName(WEBSITE, &ip)) {
Serial.println(F("Couldn't resolve!"));
cc3000.printIPdotsRev(ip);
//Get data & transform to integers
float lat = latitude;
float lon = longitude;
//JSON data
String data = "";
data = data + "\n" + "{\"version\":\"1.0.0\",\"datastreams\" : [ "
+ "{\"id\" : \"Latitude\",\"current_value\" : \"" + String(latitude) + "\"},"
+ "{\"id\" : \"Humidity\",\"current_value\" : \"" + String(longitude) + "\"}]}";
//Get Length
length = data.length();
Serial.print("Data Length");
Serial.println(length);
//Print request for debug purposes
Serial.print("PUT /v2/feed/");
Serial.print(feedID);
Serial.println(".json HTTP/1.0");
Serial.print("X-ApiKey: ");
Serial.print(API_key);
Serial.print(" Content-Length: ");
Serial.println("Connection: close");
Serial.print(data);
//Send Request
Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
if (client.connected()) {
Serial.println("Connected!");
client.println("PUT /v2/feeds/" + String(feedID) + ".json HTTP/1.0");
client.println("Host: api.xively.com");
client.println("X-ApiKey: " + String(API_key));
client.println("Content-Length: " + String(length));
client.print("Connection: close");
client.println();
client.print(data);
client.println();
Serial.println(F("You Failed"));
return;
Serial.println(F("--------------------------------------"));
while (client.connected()) {
while (client.available()) {
char c = client.read();
Serial.print(c);
client.close();
Serial.println(F("\n\nDisconnecting"));
cc3000.disconnect();
//Wait 60 seconds until next update
delay(60000);
void displayGPS() {
char field[20];
getField(field, 0);
if (strcmp(field, "$GPRMC") == 0) {
//Serial.println("TIMESTAMP VALID LATITUDE N/S LONGITUDE E/W SPEED TRUE COURSE DATESTAMP VARIATION E/W CHECKSUM")
//Serial.println(" HHMMSS A/V DMS DMS KTS º DDMMYY º ")
//Serial.println("--------------------------------------------------------------------------------------------------------------------------------------------")
Serial.println("||----------------------------||");
Serial.print("|| TIMESTAMP: ");
getField(field, 1);
Serial.println(field);
Serial.print("|| VALID: ");
getField(field, 2);
Serial.print("|| LAT: ");
getField(field, 3); // number
Serial.print(field);
getField(field, 4);
Serial.print("|| LONG: ");
getField(field, 5);
getField(field, 6);
Serial.print("|| SPEED: ");
getField(field, 7);
Serial.print("|| TMG: ");
getField(field, 8);
Serial.print("|| DATESTAMP: ");
getField(field, 9);
Serial.print("|| VARIATION: ");
getField(field, 10);
getField(field, 11);
//Serial.print(" || CHEKSUM: ");
//getField(field, 12);
//Serial.println(field);
// Serial.print("
//getField(field, 4); // N/S
//Serial.print(field);
//Serial.print(" Long: ");
//getField(field, 5); // number
//getField(field, 6); // E/W
void getField(char* buffer, int index) {
//char field[20];
int data_pos = 0;
int field_pos = 0;
int comma = 0;
while (data_pos < data_size) {
if (data[data_pos] == ',') {
comma ++;
data_pos ++;
if (comma == index) {
buffer[field_pos] = data[data_pos];
field_pos ++;
data_pos ++;
buffer[field_pos] = '\0';
When I try and compile this I get an error message saying "too few arguments to function 'void getField(char*, int)' on line 16?
There's no code on line 16
Can anyone shed some light on my predicament?
