hello friends.i have question about shifting pwm outputs on mega2560. uploaded code does 2 shifted output signal one from each other for 1 second.i set 2 phase and frequency correct mode for 2 timers,TCNT3 value is TOP-15625.My question is ho to make stable shift for variable frequency?because if i try to regulate OCR4A,OCR3A and TCNT3,it goes out of shift.Guys do u have any idea what should be best?this code is just simple for testing, im trying to figure out phase shift for 3 timers but here we can understand it better.
DDRH |= (1<<PH3) | (1<<PH4) | (1<<PH5) ;
DDRE |= (1<<PE3) | (1<<PE4) | (1<<PE5) ; //outputs 678-timer4,235-timer3
TCCR3A = 0<<COM3A1 | 1<<COM3A0 | 1<<COM3B1 | 0<<COM3B0 | 1<<COM3C1 | 1<<COM3C0
| 0<<WGM31 | 1<<WGM30 ;
TCCR3B = 1<<WGM33 | 0<<WGM32 | 1<<CS32 | 0<<CS31 | 1<<CS30 ;
TCCR4A = 0<<COM4A1 | 1<<COM4A0 | 1<<COM4B1 | 0<<COM4B0 | 1<<COM4C1 | 1<<COM4C0
| 0<<WGM41 | 1<<WGM40 ;
TCCR4B = 1<<WGM43 | 0<<WGM42 | 1<<CS42 | 0<<CS41 | 1<<CS40 ;
// phase and freq correct COMnA-top, COMnB- output noninverter COMnC-unused inverter output
// prescaler /1024
GTCCR = (1<<TSM)|(1<<PSRASY)|(1<<PSRSYNC); //stopping timer counting
TCNT3=49910; //setting timer3 to start count from this value
TCNT4=0; // TOP-OCR4/3A =tcnt3 or 0-OCR3/4A this make shift
GTCCR = 0; //release timers
OCR4A=OCR3A=15625; //0,5 hz TOP value
OCR3B=OCR3A/2; // 1hz output alternating switching OCR3B and OCR4B
OCR4B=OCR4A/2;
