Phidgets stepper motro RPM
First the setup: - Stepper motor: http://www.phidgets.com/products.php?category=23&product_id=3319 - Pololu DRV8825 high current stepper driver: http://www.pololu.com/product/2132/pictures - Stepper motor to DRV8825 wires: B2 (blue), B1 (red), A1 (black), A2 (green) - 12 V Lipo battery pack
This setup works fine for very slow rotations. The maximum RPM I achieve with this is around 0.7 RPM. But I want to rotate the motor faster to certain positions from where it then should then rotate very slowly.
I already tried to double the input voltage using 2 lipo packs in serial and changing the potentiometer on the DRV8825 board. At a certain point on the potentiometer the motor begins to stutter until it finaly completely stops (probably the DRV8825 overheats).
How can I increase the motor speed? What alternative driver could I use which is controlable by Arduino which allows more current.
#define motorSteps 200
Stepper myStepper(motorSteps, pinStep, pinDir);
  myStepper.setSpeed(300); // maximum working speed
  myStepper.step(1000L);
Regards,
The rotation speed is a software problem. With the following EasyDriver code I get better RPMs: http://bildr.org/2011/06/easydriver/ So I will skip the Stepper library and write my own stearing code.
If speed is still a problem a higher voltage supply will increase the maximum rate, the DRV8825 chip will take a supply up to 40V or so....
Doesn't the speed depend on the rate of pulses you are sending to the motor ?
