Hello, please help me, i have one phone and an IC DTMF decoder which is the responsible for decoding the keys on the remote phone and convert them into digital output to the Arduino, and arduino is the responsible for receiving the digital outputs of the DTMF decoder, treat them and trigger the device you want on / off. So now is my question... because already i have a code until this point, is an example, but i think it will work, the problem is that i don't know how to assemble the codes from the servo and dc motor with the early code to activate the servo and the dc motor.
Here is the DTMF duino code
* DTMF HOME CONTROL V1.0 Rev0.0
* Controle de dispositivos através de telefone
* Arduino-ce
* Comunidade Cearense de Hardware Livre
* http://groups.google.com/group/arduino-ce?hl=pt-br
* http://arduino-ce.blogspot.com
* março de 2011
#define RELE1 2 // Conectado ao fio branco do módulo Relé(Figura4)
#define pinBit01 7 // Q0
#define pinBit02 6 // Q1
#define pinBit03 5 // Q2
#define pinBit04 4 // Q3
#define pinBitStd 3 // STD
int tecla = 0;
int bit01 = 0;
int bit02 = 0;
int bit03 = 0;
int bit04 = 0;
int bitStd= 0;
int RELE1_STATE = LOW; // Estado do Relé LOW (Desligado)
Serial.begin(9600); // Iniciamos a Serial com Baudrate 9600
pinMode(RELE1, OUTPUT); // Definimos o pino do Relé como Saída
Serial.println("Aguardando tecla de comando..."); // Exibimos a mensagem no terminal...
void loop(){
bitStd = digitalRead(pinBitStd); //Lê o estado do pino STD e armazena em 'bitStd'
if (bitStd == HIGH) {//Se estiver em nível alto fará as leituras
//dos bits dos pinos Q3, Q2, Q1 e Q0
bit01 = digitalRead(pinBit01);
bit02 = digitalRead(pinBit02);
bit03 = digitalRead(pinBit03);
bit04 = digitalRead(pinBit04);
tecla = (bit04 * 8) + (bit03 * 4) + (bit02 * 2) + (bit01 * 1);//Conversão binária para
//decimal (ver Vídeo1)
Serial.print("Recebido: "); // Exibe a mensagem
switch (tecla){ // Seleciona a tecla pressionada
case 1: // Tecla 1
Serial.println("1");
/* COMANDO PARA RELE1 */
RELE1_STATE = !RELE1_STATE; // Guarda o estado INVERTIDO do Relé.
case 2: // Tecla 2
Serial.println("2");
case 3: // Tecla 3
Serial.println("3");
case 4: // Tecla 4
Serial.println("4");
case 5: // Tecla 5
Serial.println("5");
case 6: // Tecla 6
Serial.println("6");
case 7: // Tecla 7
Serial.println("7");
case 8: // Tecla 8
Serial.println("8");
case 9: // Tecla 9
Serial.println("9");
case 10: // Tecla 0
Serial.println("0");
case 11: // Tecla *
Serial.println("*");
case 12: // Tecla #
Serial.println("#");
digitalWrite(RELE1, RELE1_STATE);//Liga ou desliga o Relé1 conforme o estado (HIGH/ LOW)
// Zeram-se todas as variáveis
tecla = 0;
bit01 = 0;
bit02 = 0;
bit03 = 0;
bit04 = 0;
bitStd= 0;
delay (500); // Aguarda 500 milissegundos
} // Sai do switch
} // Volta pro loop...
and the servo code for example is:
#include <Servo.h>
Servo servo;
int pinLed = 13;
int pinBoton = A0;
pinMode(pinBoton,INPUT);
pinMode(pinLed,OUTPUT);
servo.attach(3,771,1750);
if {digitalRead(pinBoton)==HIGH){
digitalWrite(pinLed,HIGH);
tone(12,420,500);
digitalWrite(pinLed,LOW);
servo.write(0);
delay(1500);
servo.write(90);
delay(4000);
servo.write(0);
delay(5000);
tone(12,420,500);
else {
servo.write(90);
Maybe for some one is easy to do that, but i am new a i don't have experience, I will be very grateful for your help
Thank you very much
