Photo resistor 5 or 3,3V ESP32
Hi
Hopefully a simple question.
On my system I have both 3,3 and 5V. Uses ESP32 WROOM 32
I want to add a photo resistor to the system, GPIO26.
My fist thought was to use 5 v and in series a 4,7kOhm resistor, this to have "bigger" volts to play with.
ESP32 is a 3,3v device so now I'm not sure wat to do
Q:
Should I use 3,3 or 5v to get the best out of this, and not destroy my ESP?
M
It's a 3.3v device, and the GPIO pins should not be exposed to anything above that.
Hi
I did a test.
3.3V gives max 3.24V and minimum 0,80V.
Case closed, connect to 3.3V to not give overvoltage to ESP32.
M
