Photo resistor and relay problem.
Hi i got my arduino hooked up with an ethernet shield and an mqtt program running on it. The arduino sends data to my raspberry pi where i can monitor temp/humidity and light on node-red and i can even control a relay board with 4 relays. Everything works great till i activate a relay then the photo resistor value increase and if i activate another relay it increase again. suspect maybe a voltage drop or something. But i tought to ask if anyone have any better idea what the problem can be.
Do you have a multimeter to check the relay coil-voltage?
Have you tried a simple-little test program that just activates/sequences the relays?
Yea i got a multimeter at work. No i haven't tried the relays yet more then that they work on off all four of them. As im at home and dont have my multimeter here. like i wrote i suspect maybe a voltage drop that all i have to go on at the moment if im not missing something.
Probably caused by an insufficient power supply. What is your supply's current capacity?
With the kind of project you're doing, you should probably get one for home. If cost is an issue, a cheap meter is better than no meter.
In the meantime, you can make a tester with an LED & resistor to check for the presence of voltage, and if the voltage drops with more than one relay energized, the LED will dim.
Many years ago, I made a low-voltage tester with a meter probe, an alligator clip, two different colored LEDs, and a resistor. The LEDs are wired in opposite directions so I can check for positive or negative voltage. ...Sometimes it's handier than a meter.
Check your grounding... Take a quick look at "Common Ground Point" on this (incomplete) Page
Welcome to the forum.
Can you post a picture of your project so we can see your component layout.
What spec/type of relay are you using?
Thanks… Tom… :slight_smile:
terryking228:
Check your grounding… Take a quick look at “Common Ground Point” on this (incomplete) Page
Tnx. It was the grounding. The resistor and relay board shared the same grounding on the breadbord. When i gave the resistor a direct grounding to the arduinoboard everything worked.
