Hey, everyone. Lately I've been working on the photocell beginner lesson that came with the arduino uno. I am having a problem getting it to actually work though. I wired the LED to precisely what the program says to and I tried to make it less complicated by changing from 8 LED's to 1. So here's the code.
Bargraph sketch
Turns on a series of LEDs proportional to a value of an analog sensor.
Six LEDs are controlled but you can change the number of LEDs by changing
the value of NbrLEDs and adding the pins to the ledPins array
const int NbrLEDs = 1;
const int ledPins[] = { 5};
const int photocellPin = A0;
const int wait = 30;
// Swap values of the following two constants if cathodes are connected to Gnd
const boolean LED_ON = HIGH;
const boolean LED_OFF = LOW;
int sensorValue = 0; // value read from the sensor
int ledLevel = 0; // sensor value converted into LED 'bars'
for (int led = 0; led < NbrLEDs; led++)
pinMode(ledPins[led], OUTPUT); // make all the LED pins outputs
//sensorValue = analogRead(analogInPin); // read the analog in value
sensorValue = analogRead(photocellPin);
ledLevel = map(sensorValue, 300, 500, 0, NbrLEDs); // map to the number of LEDs
if (led < ledLevel ) {
digitalWrite(ledPins[led], LED_ON); // turn on pins less than the level
else {
digitalWrite(ledPins[led], LED_OFF); // turn off pins higher than
// the level
Is this code over complicated at all? I tried rewriting it and simplifying it, but I also don't really understand the photocell. With the program like this, everything wired to the board the LED stays on and even with the photocell covered nothing happens. What would be my first step to solving this problem? Thanks guys.
