I am trying to use two photoresistors to start and stop a timer. I want to print the elapsed time to an LCD screen.
Currently I have 2 separate photoresistors that turn on individual leds when darkened.
I have a basic "hello world" LCD code running in parallel with this circuit.
I am struggling to get the photoresistors to start and stop a timer instead of light up individual leds.
I have looked at various LCD stopwatch codes but am struggling to integrate the start/stop function with the photoresistors.
Any help would be very helpful.
Thankyou
Calum
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//Constants
const int pResistor = A0; // Photoresistor at Arduino analog pin A0
const int pResistor2 = A1; // Photoresistor at Arduino analog pin A1
const int ledPin=8; // Led pin at Arduino pin 9
const int ledPin2=9; // Led pin at Arduino pin 10
//Variables
int value; // Store value from photoresistor (0-1023)
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
pinMode(ledPin, OUTPUT); // Set lepPin - 9 pin as an output
pinMode(ledPin2, OUTPUT); // Set lepPin - 10 pin as an output
pinMode(pResistor, INPUT);// Set pResistor - A0 pin as an input (optional)
pinMode(pResistor2, INPUT);// Set pResistor - A1 pin as an input (optional)
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis() / 1);
value = analogRead(pResistor);
//You can change value "25"
if (value > 650){
startTime = millis(); //Turn LED off
else{
digitalWrite(ledPin, HIGH); //Turn led on
delay(1); //Small delay
value = analogRead(pResistor2);
if (value > 650){
digitalWrite(ledPin2, LOW); //Turn led off
else{
digitalWrite(ledPin2, HIGH); //Turn led on
I have checked and it makes no difference to the performance of the circuit. I have now removed it.
This is the up to date code, I have removed an error from the previous post.
//Constants
//Variables
lcd.begin(16, 2);
lcd.print(millis() ;
if (value > 650){
digitalWrite(ledPin, LOW); //Turn led off
else{
if (value > 650){
else{
You do understand that as soon as loop returns, it gets called again?
There's no sense in your code that you wait for the "on" condition from the first photoresistor, before waiting for the "on" condition from the second.
calmac12:
A lot of goofy code will make no difference to the performance of the circuit. However, it makes a huge difference to other people who have to read it and try to understand its purpose. It also may affect the efficiency of the code.
Your revised code won't compile.
Your comment isn't true:
You haven't explained what the 1 millisecond delays are for.
