Photogrammetry rig feasibility
Hello Arduino community! As of recently I started to develop an interest in this thing called photogrammetry. I started with a basic manual setup and decided I want to take it a step further. I've been researching different design and I came to the conclusion I want to do something crazy and challenging.
The project I have in mind is based on a 20 year old paper by Paul Debevec and involves a technique called Polarized Spherical Gradient Illumination. There have been many companies that used his research to create outstanding light stages/cages however none of these are particularly portable, let alone affordable. The idea is to create a (very) poor mans version that is portable and cheap.
I modeled the basic shape of the design:
It will be a geometric dome (two halves) made of aluminum 15mm x 15mm extrusions with 3D printed connections resulting in approximately a 1 meter tall by 1.2 meter wide & long rig. To make this thing happen I would need a (Arduino?) based lights control system with around 300 independently controllable LED chips. All of the LED's will be covered with a polarizing filter blocking some of the light (1.5 f-stops). They need to be triggered in programmable sequences and synchronized with Raspberry camera's.
I was thinking using these LED chips: link
My questions to the community is if this idea is even remotely possible. I have no prior Arduino or electronics knowledge but I know my way around coding. Thanks for reading!
LED strips like the WS2812 individually addressable LED strips might make wiring easier.
groundFungus:
Thanks for the suggestion! I think that would indeed make wiring a lot easier, however I would need white LED only strips and since they don't exist I would have to go for SK6812 RGBCW which are quite expensive.
What will the polarising filters do?
Johan_Ha:
Polarise and attenuate?
Johan_Ha:
By using polarization filters in different orientations, you can capture images of the object without reflections (cross polarization) and with double the specular reflections (paralell polarization). The difference between both images can get you an estimate of the specular values on a per-pixel level.
