Hi all, I have a project that I want to add OTA update ability to. Everything is working fine but when I add the code for the OTA and its libraries the light sensor values stop working. If I comment out the code for the OTA it works again. very strange. any suggestions??
(The code with the ** is what i comment out and it works again)
//Locking, Automatic Chicken Coop Door
//By Mike Roberts 2024 (based off of original code by Seth Johnson Land To House llc 2016)
**#include <Arduino.h>**
**#include <ElegantOTA.h>**
**#include <WiFi.h>**
**#include <WiFiClient.h>**
**#include <WebServer.h>**
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
#include <DallasTemperature.h>
#define CoolRelay 32
#define HeatRelay 33
#define ONE_WIRE_BUS 4
const boolean SerialDisplay = true; // print debug messages or not to serial
//This section is for initializing things:
//const int led = 13;
int tcrt;
const int PWM = 26; //enables PWM on the drv8801 motor controller.
const int DIR = 27; //send high or low to DIR on the motor controller.
const int red = 14; // red LED heating
const int blue = 12; // blue LED cooling
const int coopDoorOpenLed = 13;
const int coopDoorClosedLed = 23;
const int lightSensorPin = 0; //Initialize "lightSensor" This is the photoresistor.
const int BotSwtch = 18;
const int TopSwtch = 19;
int lightVal = 0;
int BotSwtchState = 0;
int TopSwtchState = 0; //These are the variables that hold the state of the reed switches
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
**//Set WiFi Credentials**
**const char *ssid = "Wi-Fi Fo Fum";**
**const char *password = "Ismo@em!!";**
**WebServer server(80);**
void setup() //This only runs once.
Serial.begin(115200); // initialize the serial communications:
**//connect to WiFi**
** WiFi.mode(WIFI_STA);**
** WiFi.begin(ssid, password);**
** while (WiFi.status() != WL_CONNECTED) {**
** delay(500);**
** Serial.println("Connecting to WiFi...");**
** Serial.println("Connected to WiFi");**
** Serial.println(ssid);**
** Serial.print("IP address: ");**
** Serial.println(WiFi.localIP()); **
** //Begin OTA**
** ElegantOTA.begin(&server); // Start ElegantOTA**
** server.begin();**
** Serial.println("HTTP server started");**
lcd.init(); // set up the LCD's number of columns and rows:
lcd.backlight();
sensors.begin();
pinMode(red, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(CoolRelay, OUTPUT);
pinMode(HeatRelay, OUTPUT);
pinMode(PWM, OUTPUT);
pinMode(DIR, OUTPUT); // set the motor control pins as outputs.
pinMode(coopDoorOpenLed, OUTPUT);
pinMode(coopDoorClosedLed, OUTPUT);
pinMode(BotSwtch, INPUT_PULLUP);
pinMode(TopSwtch, INPUT_PULLUP);
BotSwtchState = digitalRead(BotSwtch);
TopSwtchState = digitalRead(TopSwtch);
// TestBtnState = digitalRead(TestBtn);
if (BotSwtchState != HIGH) //if BotSwtchState is not high then go to the while statement
while (BotSwtchState != HIGH) // this function will run the motor down as long as switch 1 has not been triggered
analogWrite(PWM, 200); // turn on motor and set speed to 255
digitalWrite(DIR, LOW); // DIR LOW=down HIGH=up
BotSwtchState = digitalRead(BotSwtch); //read the state of the switch again to make sure that it has not been triggered
TopSwtchState = digitalRead(TopSwtch); //read the state of switch 2 (the top one) and place it in TopSwtchState
delay(100);
analogWrite(PWM, 0); // once TopSwtchState has been triggered turn off the motor
digitalWrite(coopDoorClosedLed, HIGH); // turns on coopDoorClosedLed (green)
digitalWrite(coopDoorOpenLed, LOW);
//this runs over and over
**// Handle OTA**
** server.handleClient();**
** ElegantOTA.loop();**
** //Code for OTA**
sensors.requestTemperatures();
float temperature = sensors.getTempFByIndex(0);
lightVal = analogRead(lightSensorPin); //read the light sensor and place it in lightval
lcd.home();
char buffer[50];
sprintf(buffer, "LSV: %4d", (analogRead(lightSensorPin))); // was A0 which is now 19 try 19 if lightSensorPin doesnt work
lcd.setCursor(0, 0);
lcd.print(buffer);
lcd.setCursor(10, 0);
lcd.print("Temp:"); // sprintf(buffer, "Temp: %f\337F", temperature);
lcd.print(sensors.getTempFByIndex(0));
lcd.print("\337F"); // lcd.print (buffer);
Serial.print(" Light sensor value: ");
Serial.println(analogRead(lightSensorPin));
Serial.print(" ");
Serial.print(sensors.getTempFByIndex(0));
Serial.println("\337F");
if (temperature < 40) //changed temp to 40
digitalWrite(red, HIGH);
digitalWrite(blue, LOW);
Serial.println(" Heating");
digitalWrite(CoolRelay, 0);
digitalWrite(HeatRelay, 1);
delay(3000);
} else if (temperature > 40 && temperature < 85) //changed temp to 40
digitalWrite(red, LOW);
Serial.println(" All Off");
digitalWrite(HeatRelay, 0);
} else if (temperature > 85) {
digitalWrite(CoolRelay, 1);
digitalWrite(blue, HIGH);
Serial.println(" Cooling ");
Serial.print(" Bottom Switch Value: "); // display "Bottom Switch Value:"
Serial.println(digitalRead(BotSwtch));
sprintf(buffer, "Bot Sw: %d", BotSwtchState);
lcd.setCursor(0, 1);
lcd.print(buffer);
Serial.print(" Top Switch Value: "); // display "Bottom Switch Value:"
Serial.println(digitalRead(TopSwtch));
sprintf(buffer, "Top Sw: %d", TopSwtchState);
lcd.setCursor(0, 2);
lcd.print(buffer);
if (TopSwtchState == HIGH && lightVal < 75) {
delay(30000);
motordown();
} else if (BotSwtchState == HIGH && lightVal > 400) {
delay(30000);
motorup();
void motordown() //code for sending door down
while (BotSwtchState != HIGH) {
delay(1000); //wait 1 seconds before turning off the motor to let the locks engage at the bottom
analogWrite(PWM, 0); // now turn off motor
digitalWrite(coopDoorOpenLed, LOW); // turns off coopDoorOpenLed (red)
void motorup() // this function will run the motor as long as switch 2 has not been triggered
while (TopSwtchState != HIGH) {
digitalWrite(DIR, HIGH);
digitalWrite(coopDoorClosedLed, LOW); // turns on coopDoorClosedLed (green)
digitalWrite(coopDoorOpenLed, HIGH); // turns off coopDoorOpenLed (red)
