Project: send 5v signal through a Photo-resistor, then through a 330R Resistor (which is also grounded) Then connect to analog pin A1. If the electric current into A1 is less than 3Volts turn the power to PWM pin 12 on so a second circuit is made. The code is taken from the provided pre=made code in the Arduino IDE, and tweaked to fit my needs and previous process of troubleshooting.
Code:
int sensorPin = A1; // select the input pin for the potentiometer
int pin12 = 12; // select the pin for the LED
int sensorValue = A1; // variable to store the value coming from the sensor
Serial.begin(9600); //Start serial communication with computer over USB
// declare the powerPin as an OUTPUT:
pinMode(pin12, OUTPUT);
pinMode(sensorValue, INPUT);
int sensorValRead = analogRead(A1); //Reads resistance value from A1
float voltage = sensorValRead * (5.0 / 1023.0);// calculates voltage level input by A1
Serial.println(voltage);
int sensorValRead = analogRead(A1);//Reads resistance value from A1
if(voltage >= 3.0);
// turn the ledPin on
digitalWrite(pin12, HIGH);
// stop the program for milliseconds:
delay(voltage);
Talle50:
if(voltage >= 3.0);
delay(voltage);
You wanted pin12 to have an PWM signal yet you use digitalWrite to it. This will just be a solid, unmodulated 5v. You also have the command in twice. (once conditionaly and again without any condition)
So you should have analogWrite(pin12,someValueHere) within your conditional statment and then you should delete the unconditional digitalWrite that follows it.
nilton: my original issue was that the analog A0 is not receiving an input. I've made the changes KenF suggested, and the A0 port is still not showing it getting a signal.
If the voltage is greater than 3.0, do nothing ( ; ). Otherwise, do nothing. Well, OK.
if(voltage >= 3.0);
// stop the program for <sensorValue> milliseconds:
delay(voltage);
Then, turn the pin on, wait a while, and turn the pin on. I'm sensing something wrong here. Can't quite put my finger on it, though.
try this added first
Serial.print(sensorValRead);
Serial.print(" ");
It will probably showa value for sensorValRead,but 0 for voltage.
I think you have to declare sensorValRead as a float for the equation to work correctly.
So edit this line to add float;
float voltage = float sensorValRead * (5.0 / 1023.0);// calculates voltage level input by A1
Hope it, helps, mind getting into gear, first coffee of the day.
Tom.........
Update: I have tried the suggestions up until the one suggested by TomGeorge, been very busy with academics but will try each suggested solution once more and give another update after that. My apologies for the mess of code originally posted.
How do I make a post where there is the specific section for code rather than posting it as normal text?
