float target
<?php //데이터베이스 연결 $connect = mysql_connect("localhost","root","***********8"); //데이터베이스 선택 $db_con=mysql_select_db("arduino",$connect); //DB에 데이터 입력 $sql = "SELECT * FROM `targetTemp`"; $result = mysql_query($sql,$connect); $records = mysql_num_rows($result); // mysql_num_rows 인자의 레코드 개수를 알려준다 $fields=mysql_num_fields($result); // mysql_num_fields인자의 필드개수를 알려준다 $number=1; ?>
Target Temperature
<?php for($i =0; $i < $records; $i++){ echo""; echo""; for($j=0; $j< $fields; $j++){ $data = mysql_result ($result, $i, $j); // 레코드위 특정위치에 저장된 값을 가져온다 echo ""; } echo""; $number++; } ?>php code
#include <ESP8266WiFi.h>
#include <SPI.h>
char ssid = "hdh"; // your network SSID (name)
char pass = ""; // your network password
//int status = WL_IDLE_STATUS;
WiFiClient client;
char server = "******";
float targetTemp;
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Starting the web server
Serial.println("Web server running. Waiting for the ESP IP...");
delay(5000);
// Printing the ESP IP address
delay(5000); // GIVE THE SENSOR SOME TIME TO START
if (client.connect(server,80)) { // REPLACE WITH YOUR SERVER ADDRESS
Serial.println("connected");
client.print("GET /target1.php?");
// client.print("target=");
// client.println(targetTemp);
client.print("HTTP/1.1");
client.println("Host: ****************");
client.println("Content-Type: application/x-www-form-urlencoded" );
client.println("Connection: close");
client.println();
delay(2000);
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while(true);
arduio code
Access to php is possible. Through WiFi communication, I'm trying to place the target of php in the aduino targetTemp. On the serial monitor, it appears that the ASCII code 'H '.
I hope that 26.5(target) of php will be delivered to aduino. help me!
number | target |
$number | $data |
