# PHP data processing
**URL:** <https://forum.arduino.cc/t/php-data-processing/520475>\
**Category:** General Guidance\
**Created:** [April 15, 2018, 4:52pm UTC](https://forum.arduino.cc/t/php-data-processing/520475 "2018-04-15T16:52:13Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Jaim\_Arif](https://avatars.discourse-cdn.com/v4/letter/j/ac91a4/32.png) [@Jaim\_Arif](https://forum.arduino.cc/u/Jaim_Arif)\
**Post date:** [April 15, 2018, 4:52pm UTC](https://forum.arduino.cc/t/php-data-processing/520475/1 "2018-04-15T16:52:13Z")
</div>
I need to know how can i send my raw data (1 or 0) to php script to process the data and send to mysql database. I'm using wired arduino ethernet shield. I have try many solution i can get from the internet, but none succeed. I need help to understand how to send the data and improve my code.
Thank you for helping.
Here are my sketch to get the data.
```cpp
 * Libraries included
#include <Ethernet.h>
#include <SPI.h>
#include <UbidotsEthernet.h>
 * Constants and objects
/* Assigns the Ubidots parameters */
char const * TOKEN = "A1E-KIoScrrIu1RTgxDSlKYy1WA3NWQ9Kq"; // Assign your Ubidots TOKEN
char const * VARIABLE_LABEL_1 = "sensor"; // Assign the unique variable label to send the data
/* Enter a MAC address for your controller below */
/* Newer Ethernet shields have a MAC address printed on a sticker on the shield */
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
/* initialize the instance */
Ubidots client(TOKEN);
 * Main Functions
 int floatswitch = 7;
  pinMode(floatswitch, INPUT);
  //client.setDebug(true);// uncomment this line to visualize the debug message
  /* start the Ethernet connection */
  Serial.print(F("Starting ethernet..."));
  if (!Ethernet.begin(mac)) {
    Serial.println(F("failed"));
    Serial.println(Ethernet.localIP());
  /* Give the Ethernet shield a second to initialize */
  delay(2000);
  Serial.println(F("Ready"));
  Ethernet.maintain();
  /* Sensors readings */
  int result = digitalRead(floatswitch);
  /* Sending values to Ubidots */
  client.add(VARIABLE_LABEL_1, result);
  client.sendAll();
  delay(5000);
**Author:** ![PaulRB](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/paulrb/32/216330_2.png) [@PaulRB](https://forum.arduino.cc/u/PaulRB)\
**Post date:** [April 15, 2018, 5:32pm UTC](https://forum.arduino.cc/t/php-data-processing/520475/2 "2018-04-15T17:32:46Z")
</div>
> but none succeed
That is not good enough, you must try harder. No-one can help you if you just say "it doesn't work". You must be more precise in your description. What happened? What did you want or expect to happen? Were there any error messages? If so, what?
Perhaps if you look at [my code](https://github.com/PaulRB/WemosSensor) that will give you some clues.
**Author:** ![6v6gt](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/6v6gt/32/225488_2.png) [@6v6gt](https://forum.arduino.cc/u/6v6gt)\
**Post date:** [April 15, 2018, 8:39pm UTC](https://forum.arduino.cc/t/php-data-processing/520475/3 "2018-04-15T20:39:59Z")
</div>
Start by writing a PHP script which is initiated by a URL something like:
[http://www.mydomain.com/floatSwitch?level=1](http://www.mydomain.com/floatSwitch?level=1)
The PHP script takes the value of level (which is 1 in this example) and writes it to a table in a mySQL database maybe with a time stamp etc.
You can test this simply by using a web browser, that is without using the arduino.
Once you get that working, from the arduino use an HTTP GET command to issue the same URL.
**Post date:** [May 5, 2021, 6:32pm UTC](https://forum.arduino.cc/t/php-data-processing/520475/4 "2021-05-05T18:32:51Z")
</div>
