I have a simple device that reads a RFID card and I want to put that information to the web. I am having trouble getting the arduino to connect/push the data.
I know the server/php/mysql is working because I can manually add data from the browser e.g. http://www.storemyRFIDcard.com//add.php?cardUID=05 5D 72 D4&&cardPresent=1&&macAddress=11:11:11:11:11:11&&dateTime=2014-03-1 01:01:01
When I add from the browser, everything shows up on the page as expected.
Additionally, the Ethernet is working because I can get NTP time and run various sketches. The below code is pulled from the WebClient example. I just changed the server and GET lines.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x11, 0x11, 0x11 0x11, 0x11, 0x11 };
char server[] = "http://www.storemyRFIDcard.com/";
IPAddress ip(192,168,0,177);
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
client.println("GET /add.php?&cardUID=05 5D 72 D4&&cardPresent=1&&macAddress=11:11:11:11:11:11&&dateTime=2014-03-1 03:04:05");
client.println("Host: www.storemyRFIDcard.com");
client.println("Connection: close");
client.println();
else {
Serial.println("connection failed");
if (client.available()) {
char c = client.read();
Serial.print(c);
if (!client.connected()) {
Serial.println("Done");
client.stop();
// do nothing forevermore:
while(true);
I know its not secure/best practice but if I could simply get the arduino to do the same thing as the manually adding through the webpage I'd be happy. Any observations/thoughts/ideas?
Because your web browser url encodes that string for you. It becomes something like this. Note the spaces have become %20. This is called "url encoding". I removed the double ampersands.
Switch to HTTP/1.0 so you don't have to worry about persistent connections. Should probably keep the "%20" space encoding suggested by SurferTim or (even better) eliminate the need for those spaces in your add.php script.
First, change the request to a simple page on that server that does return a response. Insure you are going to the correct website.
Second, I don't see on that add.php page where it gets the values for the variables you sent. I can't tell what is on conect.php, and you are sending a Location value of insertareg.php. ??
I'm just pulling code from examples and removed the reference to insertareg.php. Now it seems to be working and I'm getting a response from the server. Thanks for the help, I really appreciate it.
Here is my URI encoder you might find useful ( also called percent encoding ). If there is binary data to send I have a Base64 encoder too. Will make it easy to create a URL. http://forum.arduino.cc/index.php?topic=202264.0
