PHP page display value from arduino webserver
Hello!
I’m not sure if the topic is on this forum, but I still ask for help.
I play with rasberry pi3 and arduino web server with temperature value.
On Raspberry Pi i have PHP page, Which reads the values from arduino server.
I want to push these values into php code with temperature GAUGE, but no luck.
<?php
function get_string_between($string, $start, $end){
        $string = " ".$string;
        $ini = strpos($string,$start);
        if ($ini == 0) return "";
        $ini += strlen($start);
        $len = strpos($string,$end,$ini) - $ini;
        return substr($string,$ini,$len);
$arduino92 = file_get_contents("http://192.168.5.92/");
$data_val = get_string_between($arduino92, "Kurilnica temp.: [", "]")
	echo "TEST: $data_val"."
<script type="text/javascript">
    setTimeout (
        function() { window.location.reload(); },
        5000
</script>
and here is INDEX.HTML from
Arduino SD card two gaude
I change last part of index.html to:
<!-- Gauge Code Ends -->
data_val  = 30.30
data_val2 = 40.40
    </script>
    </head>
    <body onload="GetArduinoInputs()">
        <h1>Arduino Two Temperatures</h1>
        <canvas id="an_gauge_1" data-title="Inside" data-units="Temp. &deg;C" width="500" height="500" data-major-ticks="-40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150" data-type="canv-gauge" data-min-value="-40" data-max-value="150" data-highlights="-40 0 #4D89F2, 0 10 #25B8D9, 10 30 #0BB950, 30 40 #cc5, 40 150 #f33" data-onready="setInterval( function() { Gauge.Collection.get('an_gauge_1').setValue(data_val);}, 200);"></canvas>
        <canvas id="an_gauge_2" data-title="Outside" data-units="Temp. &deg;C" width="500" height="500" data-major-ticks="-40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150" data-type="canv-gauge" data-min-value="-40" data-max-value="150" data-highlights="-40 0 #4D89F2, 0 10 #25B8D9, 10 30 #0BB950, 30 40 #cc5, 40 150 #f33" data-onready="setInterval( function() { Gauge.Collection.get('an_gauge_2').setValue(data_val2);}, 200);"></canvas>
    </body>
</html>
and nice show gauge with value Which I set in “data_val”
when i merge ( add line for read from server) “data_val” not Determine the values from the server
In next post i add my try merge code in php
Here i try merge code but no luck.
Gauge = 0
Print on the end is correct (value from server)
Where should I put this lines to work gauge ?
<!DOCTYPE html>
<html>
    <head>
        <title>Arduino Two Temperaturesa</title>
        <script>
         var data_val = 0;
        var data_val2 = 0;
<!-- Gauge Code Starts -->
var Gauge=function(b){function l(a,b){for(var c in b)"object"==typeof b[c]&&"[object Array]"!==Object.prototype.toString.call(b[c])&&"rende$
typeof a.delta?a.delta:M[a.delta])(c);a.step(f);1==c&&clearInterval(G)},a.delay||10)}function k(){G&&clearInterval(G);var a=I-n,h=n,c=b.ani$
"rgba(0, 0, 0, 0.5)");a.beginPath();a.arc(0,0,m,0,2*Math.PI,!0);a.fillStyle=g("#ddd","#aaa",m);a.fill();a.restore();a.beginPath();a.arc(0,0$
(h=-1<a.indexOf("."),-1<a.indexOf("-")?"-"+(b.majorTicksFormat["int"]+b.majorTicksFormat.dec+2+(h?1:0)-a.length)+a.replace("-",""):""+(b.ma$
1)))),a.beginPath(),a.moveTo(0,m),a.lineTo(0,m-15*(f/100)),a.stroke(),a.restore(),a.save();b.strokeTicks&&(a.rotate(e(90)),a.beginPath(),a.$
F(m,e(45+h*(270/(b.majorTicks.length-1))));a.font=20*(f/200)+"px Arial";a.fillStyle=b.colors.numbers;a.lineWidth=0;a.textAlign="center";a.f$
Math.sin(b),f=Math.cos(b);return{x:0*f-a*c,y:0*c+a*f}}function N(){a.save();for(var m=81*(f/100),h=m-15*(f/100),c=0,g=b.highlights.length;c$
a.beginPath();a.rotate(e(90));a.arc(0,0,h,k-0.2,r+0.2,!1);a.restore();a.closePath();a.fillStyle=b.colors.plate;a.fill();a.save()}}function $
0);a.lineTo(-1,c);a.lineTo(1,c);a.lineTo(k,0);a.lineTo(r,-d);a.closePath();a.fillStyle=g(b.colors.needle.start,b.colors.needle.end,c-d);a.f$
function L(){a.save();a.font=40*(f/200)+"px Led";var b=x(y),h=a.measureText("-"+x(0)).width,c=f-33*(f/100),g=0.12*f;a.save();var d=-h/2-0.0$
2,f/10,0,c-0.12*f-0.025*f+(0.12*f+0.045*f)/2,f/5);d.addColorStop(0,"#888");d.addColorStop(1,"#666");a.strokeStyle=d;a.lineWidth=0.05*f;a.st$
maxValue:100,minValue:0,majorTicks:[],minorTicks:10,strokeTicks:!0,units:!1,valueFormat:{"int":3,dec:2},majorTicksFormat:{"int":1,dec:0},gl$
function(a){n=b.animation?y:a;var d=(b.maxValue-b.minValue)/100;I=a>b.maxValue?b.maxValue+d:a<b.minValue?b.minValue-d:a;y=a;b.animation?k()$
y=b.minValue;if(!b.renderTo)throw Error("Canvas element was not specified when creating the Gauge object!");var z=b.renderTo.tagName?b.rend$
c=1;;b+=c,c/=2)if(a>=(7-4*b)/11){a=-Math.pow((11-6*b-11*a)/4,2)+Math.pow(c,2);break a}a=void 0}return 1-a},elastic:function(a){a=1-a;return$
a.fillStyle=b.colors.units,a.textAlign="center",a.fillText(b.units,0,f/3.25),a.restore());A.i8d=!0;a=g.ctx;delete g.ctx}a.clearRect(-t,-u,C$
(function(){var b=document,l=b.getElementsByTagName("head")[0],q=-1!=navigator.userAgent.toLocaleLowerCase().indexOf("msie"),v="@font-face $
var e=b.createElement("div");e.style.fontFamily="Led";e.style.position="absolute";e.style.height=e.style.width=0;e.style.overflow="hidden";$
Gauge.Collection.get=function(b){if("string"==typeof b)for(var l=0,q=this.length;l<q;l++){if((this[l].config.renderTo.tagName?this[l].confi$
domReady(function(){function b(b){for(var e=b[0],d=1,g=b.length;d<g;d++)e+=b[d].substr(0,1).toUpperCase()+b[d].substr(1,b[d].length-1);retu$
g.substr(0,5)){var d=g.substr(5,g.length-5).toLowerCase().split("-");if(g=k.getAttribute(g))switch(d[0]){case "colors":d[1]&&(e.colors||(e.$
s[0]&&""!=s[0]&&(x.from=s[0]);s[1]&&""!=s[1]&&(x.to=s[1]);s[2]&&""!=s[2]&&(x.color=s[2]);e.highlights.push(x)}break;case "animation":d[1]&&$
e[d]=g}}e=new Gauge(e);k.getAttribute("data-value")&&e.setRawValue(parseFloat(k.getAttribute("data-value")));k.getAttribute("data-onready")$
/data_val   = 20.70
//data_val1  = 30,30
    </script>
        <canvas id="an_gauge_1" data-title="Inside" data-units="Temp. &deg;C" width="500" height="500" data-major-ticks="-40 -30 -20 -10 0 $
        <canvas id="an_gauge_2" data-title="Outside" data-units="Temp. &deg;C" width="500" height="500" data-major-ticks="-40 -30 -20 -10 0$
    </body>
</html>
<?php
$data_val = get_string_between($arduino92, "Kurilnica temp.: [", "]");
echo "VALUE: $data_val"."
