Hi all,
i'm try to use:
- Wmplayer with Ubuntu --> php and apache correctly installed and working
- php_serial.class.php --> download and save into the same directory where I've my test.php file
- /dev/ttyACM0 --> ubuntu serial port --> working with a simply skecth
so inside the test.php file I've that:
<html>
<body>
<h1>It works!</h1>
<p>ARDUINO PHP.</p>
<p>The web server software is running but no content has been added, yet.</p>
<p>dentro allo script</p>
<?php
require("php_serial.class.php");
function writeToArduino($str){
$serial = new phpSerial();
$serial->deviceSet("/dev/ttyACM0");
$serial->confBaudRate(9600);
$serial->confCharacterLength(8);
$serial->deviceOpen();
for ($i=0; $i<strlen($str); $i++){
$serial->sendMessage($str[$i]);
$serial->deviceClose();
$tmptext = "12345ABCDE";
writeToArduino($tmptext);
</body>
</html>
and on my arduino scheth I've that:
int incomingByte = 0; // for incoming serial data
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
// send data only when you receive data:
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
// say what you got:
Serial.print("I received: ");
Serial.println(incomingByte, DEC);
so due the fact seems that doesn't send the data to the serial port ... what I can check ?
thanks Andrea
