Php web page + Nodemcu
Dear all,
I need some guideline to complete my project. Here is sample code where i could able to connect or any wifi network based on SSID.
  1. In attached image how can i change Time to Indian Standard date & time
    2)My first page should look like Online Monitoring System (Arduino, PHP, Web Server) - YouTube as shown in video . where i could able to view parameter like this. keeping auto connect page same.
  2. please suggest me in PHP how can i create my first webpage . All data is going to monitor locally.
  Simple.ino, Example for the AutoConnect library.
  Copyright (c) 2018, Hieromon Ikasamo
  https://github.com/Hieromon/AutoConnect
  This software is released under the MIT License.
  https://opensource.org/licenses/MIT
#if defined(ARDUINO_ARCH_ESP8266)
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#elif defined(ARDUINO_ARCH_ESP32)
#include <WiFi.h>
#include <WebServer.h>
#endif
#include <time.h>
#include <AutoConnect.h>
ESP8266WebServer Server;
WebServer Server;
#endif
AutoConnect      Portal(Server);
AutoConnectConfig   Config;       // Enable autoReconnect supported on v0.9.4
#define TIMEZONE    (3600 * 0530)    // Tokyo
#define NTPServer1  "ntp.nict.jp" // NICT japan.
//#define NTPServer1  "in.pool.ntp.org"
#define NTPServer2  "time1.google.com"
void rootPage() {
  String  content =
    "<html>"
    "<head>"
    "<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">"
    "</head>"
    "<body>"
    "<h2 align=\"center\" style=\"color:blue;margin:20px;\">Hello, world</h2>"
    "<h3 align=\"center\" style=\"color:gray;margin:10px;\">{{DateTime}}</h3>"
    "<p style=\"padding-top:10px;text-align:center\">" AUTOCONNECT_LINK(COG_32) "</p>"
    "</body>"
    "</html>";
  static const char *wd[7] = { "Sun","Mon","Tue","Wed","Thr","Fri","Sat" };
  struct tm *tm;
  time_t  t;
  char    dateTime[26];
  t = time(NULL);
  tm = localtime(&t);
  sprintf(dateTime, "%04d/%02d/%02d(%s) %02d:%02d:%02d.",
    tm->tm_year + 1900, tm->tm_mon + 1, tm->tm_mday,
    wd[tm->tm_wday],
    tm->tm_hour, tm->tm_min, tm->tm_sec);
  content.replace("{{DateTime}}", String(dateTime));
  Server.send(200, "text/html", content);
  //delay(1000);
  // Behavior a root path of ESP8266WebServer.
  Server.on("/", rootPage);
  // Enable saved past credential by autoReconnect option,
  // even once it is disconnected.
  Config.autoReconnect = true;
  Portal.config(Config);
  // Establish a connection with an autoReconnect option.
  if (Portal.begin()) {
    Serial.println("WiFi connected: " + WiFi.localIP().toString());
    configTime(TIMEZONE, 0, NTPServer1, NTPServer2);
  Portal.handleClient();
The basic architecture of your system has not been made very clear with respect to the roles of the Arduino and the PHP server.
Are you (1) making the arduino the web server, hosting the pages you have shown, and using PHP (on a remote server) to provide the data displayed from other sources, say an SQL server or are you (2) going to have the web server (say apache) running near the PHP server and getting its data from the Arduino (somehow) ?
Dear sir.
I wanted to created web page like mentioned Webpage1. my first window should look like webpage1 .
Its only monitoring of data, we are not recording any kind of data.
These thing i wanted .
  1. Display data paramter
  2. Serial send request and read response
