Physical pin compatibility with nano screw terminal adapter boards
I know nano boards are not pin compatible with mkr boards since their pins are not used in the same order and purpose and they even have different pin numbers, but is it physically the same? I wanted to use an screw adapter to facilitate maintenance on site of my final board, but I cannot find an screw terminal adapter board for mkr.
Would the MKR board with 14 pins on each row be inserted properly into the 15 pins per row of the nano adapter? Is the distance between the rows the same?
I have been told the distance between pins of the same row is standard, otherwise it would not be insertable into standard development boards, so that should not be a concern.
For reference, I want to insert my Arduino MKR GSM 1400 into this screw terminal adapter
Thanks
No, the distance is different. According to PCB files from Arduino site store, MKR has about 20.2-20.3 mm between pin rows, but classical Nano 16.25 mm only
