I'm trying to make a demonstration tool to show how red, green, and blue light can be combined in different amounts to achieve pretty much any color.
Ideally I would like to have three potentiometers. Each one controlling it's own leg of an RGB led. But using the code I wrote, and the configuration of my components I get nothing from the led.
RGB led datasheet:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2760028_DS_EN.pdf
I concocted this code using a LillyPad tutorial as an example:
http://web.media.mit.edu/~leah/LilyPad/06_rgb_code.html
int anodePin = 13;
int redPin = 2;
int bluePin = 4;
int greenPin = 6;
int rpotPin = 0;
int gpotPin = 1;
int bpotPin = 3;
int rval = 0;
int gval = 0;
int bval = 0;
int red = 0;
int green = 0;
int blue = 0;
int r = 0;
int g = 0;
int b = 0;
pinMode(anodePin, OUTPUT); // sets the anodePin to be an output
pinMode(redPin, OUTPUT); // sets the redPin to be an output
pinMode(greenPin, OUTPUT); // sets the greenPin to be an output
pinMode(bluePin, OUTPUT); // sets the bluePin to be an output
void loop() // run over and over again
rval = analogRead(rpotPin); // read the value from the potentiometer
gval = analogRead(gpotPin); // read the value from the potentiometer
bval = analogRead(bpotPin); // read the value from the potentiometer
red = map(rval, 0, 1023, 0, 255); // maps the potentiometer reading to led
green = map(gval, 0, 1023, 0, 255); // maps the potentiometer reading to led
blue = map(bval, 0, 1023, 0, 255); // maps the potentiometer reading to led
r = map(red, 0, 255, 255, 0); // maps led anode values to cathode values
g = map(green, 0, 255, 255, 0); // maps led anode values to cathode values
b = map(blue, 0, 255, 255, 0); // maps led anode values to cathode values
color(r, g, b); // sends code to led
void color (unsigned char red, unsigned char green, unsigned char blue) // the color generating function
analogWrite(r, 255-red);
analogWrite(g, 255-blue);
analogWrite(b, 255-green);
I'm pretty sure I not only have issues in my program, but also in my understanding of how the RGB led itself works. Any help, or suggestions would be greatly appreciated.
