I have picked up a raspberry pi pico and instead of learning micro python I have discovered I can program with Arduino IDE.
I have wired my project using DHT11, DS1302, 3 buttons and max7219 8x32 LED.
The max7219 isnt displaying anything readable. I have buttons connected and the display changes when pushed. Some screens scroll from top to bottom, others random dots. I have rotated the display code but does nothing. I tried using 'max72xx.h' but the display didn't work but the 'LedControl.h' file at least displays something.
Below is my code
#include <DHT.h>
#include <DS1302.h>
#include <LedControl.h>
//DHT11
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
//DS1302
#define DS1302_SCLK 3
#define DS1302_IO 4
#define DS1302_CE 5
DS1302 rtc(DS1302_SCLK, DS1302_IO, DS1302_CE);
//max7219
#define MAX7219_DIN 6
#define MAX7219_CS 7
#define MAX7219_CLK 8
LedControl lc = LedControl(MAX7219_DIN, MAX7219_CLK, MAX7219_CS, 1);
//buttons
#define BTN_SCROLL 9
#define BTN_ADJ_HOUR 10
#define BTN_ADJ_MINUTE 11
dht.begin();
rtc.halt(false);
rtc.writeProtect(false);
lc.shutdown(0, false);
lc.setIntensity(0, 8);
lc.clearDisplay(0);
pinMode(BTN_SCROLL, INPUT_PULLUP);
pinMode(BTN_ADJ_HOUR, INPUT_PULLUP);
pinMode(BTN_ADJ_MINUTE, INPUT_PULLUP);
static int displayMode = 0;
static unsigned long lastUpdate = 0;
const unsigned long updateInterval = 1000;
if (millis() - lastUpdate >= updateInterval) {
lastUpdate = millis();
switch (displayMode) {
case 0: showTime(); break;
case 1: showDate(); break;
case 2: showTemperature(); break;
case 3: showHumidity(); break;
if (digitalRead(BTN_SCROLL) == LOW) {
displayMode = (displayMode + 1) % 4;
delay(200);
if (digitalRead(BTN_ADJ_HOUR) == LOW) {
adjustHour();
delay(200);
if (digitalRead(BTN_ADJ_MINUTE) == LOW) {
adjustMinute();
delay(200);
void showTime() {
Time t = rtc.time();
char buffer[10];
sprintf(buffer, "%02d:%02d:%02d", t.hr, t.min, t.sec);
displayText(buffer);
void showDate() {
char buffer[10];
sprintf(buffer, "%02d-%02d-%04d", t.date, t.mon, t.yr);
void showTemperature() {
float temp = dht.readTemperature();
char buffer[10];
sprintf(buffer, "Temp: %.1fC", temp);
void showHumidity() {
float hum = dht.readHumidity();
char buffer[10];
sprintf(buffer, "Hum: %.1f%%", hum);
void displayText(const char* text) {
lc.clearDisplay(0);
int length = strlen(text);
if (length > 8) {
scrollText(text);
for (int i = 0; i < length; i++) {
lc.setChar(0, 7 - i, text[i], false);
void scrollText(const char* text) {
for (int pos = 0; pos <= length - 8; pos++) {
lc.clearDisplay(0);
for (int i = 0; i < 8; i++) {
if (text[pos + i] != '\0') {
lc.setChar(0, 7 - i, text[pos + i], false);
delay(200);
void adjustHour() {
t.hr = (t.hr + 1) % 24;
rtc.time(t);
void adjustMinute() {
t.min = (t.min + 1) % 60;
rtc.time(t);
