I have been working on designing a development board based on the Picaxe 08M2 (A relatively basic mcu). I am pretty new to designing the types of circuits for a board like this(so I probably made some mistakes), and was wondering if someone could go over my schematic for mistakes which is here: https://easyeda.com/1508543/picaxe.
IMO, your power traces should be thicker and the traces "further apart" (especially near P2)
You are missing bypass caps for each chip that are "recommended" (one or more per chip.) You can probably get away with this on the PICAXE itself, since it's a very small board that has the voltage regulator caps "nearby", but I think that FT232 chip NEEDS a cap on the 3V3OUT pin.
You don't have the usual ferrite bead and 10nf cap recommended for USB bypass (it'll probably work fine anyway), and the 100uF cap on Vcc probably violates USB spec when the jumper is set for power from the USB connector.
westfw:
Thanks! I added most of what you said, and the board looks pretty good. And I'll make sure to post anything else about this on the Picaxe forums @spycatcher2k !
