I've been using the excellent TinyGPS++ library for a NMEA GPS project. Whilst I can print the contents of the decoded NMEA sentence easily, how do I perform some math or logic on the data?
For example:
Serial.print(pdopA.value()); // will print the pdop value
printFloat(gpsA.location.lat(); // will print the latitude
but what if I wanted to only print the latitude if the pdop was less than 2.0. I thought something like this:
if (pdopA.value() <= 2.0);
but I get an compilation error of : ISO C++ forbids comparison between pointer and integer.
So, I thinks its because I am trying to perform logic on a called value from the library? But as I am fairly new to this I am unsure of how to over come this.
Why is there a semicolon on the end of that statement? What that semicolon does is define what to do when the statement is true. It means noop - do nothing. If the statement is not true, do nothing, too. So, why bother with the test?
Without the ; on the end, the code in the curly braces that starts on the next line is the body of the statement, resulting in radically different behavior.
Not with the code you posted. Post your REAL code.
Okay, yes my newbie mistake on the ;. Maybe the question I asked was not clear, and the code I posted was a brief outline on how to pick up decoded values by the TinyGPS++ library and not my actual code. It was meant to be an example of trying to pick up the contents of the .value() used in the TinyGPS++ library. I think its a fundamental way on how the library works??
To put my question another way, how do I only continue into the next part of the loop, to print extracted position, only when, for example, the pdop, hdop, or number of satellites is less than or greater than a number I specify?
