(Pictures) Wireshark shows UDP being sent, but they disapear at server
I'm closer than ever to finishing this. My Arduino Rev 2 creates an access point successfully:
My Arduino client successfully connects to it and sends dummy data:
Wireshark shows it being sent:
The server is not receiving it. It dissapears somehow.
Pastebins:
Client Code
Server Code
All of my hair is pulled out on this one. Can anyone assist?
Thank you in advance
To put your code in a code box, use the </> icon in the far left of the post tool bar and paste your code between the two bracket sets that appear.
To go back and put your code in a code box, in the bottom right of your post, select “more” and click modify. When the modify post opens, high light your code and click the </> in the far left of the post tool bar. This will put you code in code brackets. Then save the changes.
Ok, it was suggested to me that PASTEBIN is accepted because it makes the code easier to read. Nonetheless, here is the Client/Server code. Can you kindly assist me?
CLIENT:
#include <SPI.h>
#include <WiFiNINA.h>
#include <WiFiUdp.h>
char ssid[] = "SONNE";        // your network SSID (name)
char pass[] = "PWD";    // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;     // the Wifi radio's status
WiFiUDP Udp;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the data:
  Serial.print("You're connected to the network");
  printCurrentNet();
  printWifiData();
  // check the network connection once every 10 seconds:
  delay(10000);
  printCurrentNet();
     Udp.beginPacket((192,168,4,1), 6555);
    Udp.write("UDP sent Hello");
    Udp.endPacket();
void printWifiData() {
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  Serial.println(ip);
  // print your MAC address:
  byte mac[6];
  WiFi.macAddress(mac);
  Serial.print("MAC address: ");
  printMacAddress(mac);
void printCurrentNet() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print the MAC address of the router you're attached to:
  byte bssid[6];
  WiFi.BSSID(bssid);
  Serial.print("BSSID: ");
  printMacAddress(bssid);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.println(rssi);
  // print the encryption type:
  byte encryption = WiFi.encryptionType();
  Serial.print("Encryption Type:");
  Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
  for (int i = 5; i >= 0; i--) {
    if (mac[i] < 16) {
      Serial.print("0");
    Serial.print(mac[i], HEX);
    if (i > 0) {
      Serial.print(":");
SERVER:
#include <SPI.h>
#include "arduino_secrets.h"
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
WiFiServer server(6555);
  while (!Serial) {
  Serial.println("Access Point Web Server");
    // don't continue
    while (true);
  // by default the local IP address of will be 192.168.4.1
  // you can override it with the following:
  // WiFi.config(IPAddress(10, 0, 0, 1));
  // print the network name (SSID);
  Serial.print("Creating access point named: ");
  // Create open network. Change this line if you want to create an WEP network:
  status = WiFi.beginAP(ssid, pass);
  if (status != WL_AP_LISTENING) {
    Serial.println("Creating access point failed");
    // don't continue
    while (true);
  delay(10000);
  // start the web server on port 80
  server.begin();
  // you're connected now, so print out the status
  printWiFiStatus();
  // compare the previous status to the current status
  if (status != WiFi.status()) {
    // it has changed update the variable
    status = WiFi.status();
    if (status == WL_AP_CONNECTED) {
      // a device has connected to the AP
      Serial.println("Device connected to AP");
      // a device has disconnected from the AP, and we are back in listening mode
      Serial.println("Device disconnected from AP");
  WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println("new client");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void printWiFiStatus() {
  // print your WiFi shield's IP address:
  Serial.println(ip);
  // print where to go in a browser:
  Serial.print("Listening...");
  Serial.println(ip);
Your code has some stuff that didn’t want to compile on my wemos ESP8266 board, so I looked at the below simple AP/server code. If this will compile for your board, you might give it a try. The response is static but I added the “got a client” print to the serial monitor for viewing there. Note the port change and SSID and password difference.
   Copyright (c) 2015, Majenko Technologies
   All rights reserved.
   Redistribution and use in source and binary forms, with or without modification,
   are permitted provided that the following conditions are met:
 * * Redistributions of source code must retain the above copyright notice, this
     list of conditions and the following disclaimer.
 * * Redistributions in binary form must reproduce the above copyright notice, this
     list of conditions and the following disclaimer in the documentation and/or
     other materials provided with the distribution.
 * * Neither the name of Majenko Technologies nor the names of its
     contributors may be used to endorse or promote products derived from
     this software without specific prior written permission.
   THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
   ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
   WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
   DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
   ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
   (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
   LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
   ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
   (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
   SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Create a WiFi access point and provide a web server on it. */
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#ifndef APSSID
#define APSSID "ESP8266-ZK"
#define APPSK  "zoomkat"
#endif
/* Set these to your desired credentials. */
const char *ssid = APSSID;
const char *password = APPSK;
ESP8266WebServer server(80);
/* Just a little test message.  Go to http://192.168.4.1 in a web browser
   connected to this access point to see it.
void handleRoot() {
  server.send(200, "text/html", "<h1>You are connected</h1>");
  Serial.println("Got a client!");
  Serial.print("Configuring access point...");
  /* You can remove the password parameter if you want the AP to be open. */
  WiFi.softAP(ssid);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.on("/", handleRoot);
  server.begin();
  Serial.println("HTTP server started");
  server.handleClient();
