I am trying to program my arduino uno using Example of PID controller.
but getting error as below:
error: 'PID' does not name a type
what is the problem?
with compiler or code??
Code.
Probably the code you didn't show us or install correctly.
#include <PID_v1.h>
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
//initialize the variables we're linked to
Input = analogRead(0);
Setpoint = 100;
//turn the PID on
myPID.SetMode(AUTOMATIC);
myPID.Compute();
analogWrite(3,Output);
. . . or even post correctly. {sigh}
Where did you put the PID_v1 library?
it is in my downloads file
it is in my "downloads" folder
The IDE doesn't look there for libraries. There should be a libraries folder in the folder where your sketches are. If not, create one and then copy the PID library folder there. Restart the IDE and you should hopefully get better results.
The compiler won't find it there, it needs to be in your "libraries" folder.
Start here
