I'm looking for some comments suggestions for a newbie who is just starting with Arduinos. Much to learn but looking for nudge in the right direction.
I am trying to create an Arduino controlled ceramic heater element. I have a Hakko soldering iron heater element and basically I am trying to make the arduino control the heater temperature to a set point and to use the built in K-type thermocouple as the feedback for the PID loop.
The heater will be powered by a separate 12V power supply using a logic level N channel MOSFET trigered by the arduino. The K type thermo couple is read by the arduino via a MAX 6675 chip.
I'm really at the beginnings of the arduino software side but through my reading I have found a library (MAX6675)that reads the K type and converts to a digital input through the SPI.
My question are these:
- Can I use the standard PID libraries for this? They all seem to only reference an analog input? How hard would it be to use the digital signal that is read by the MAX6675?
-I guess I'm really looking for a good example to look at that is similar to this, I seem to be a bit overwhelmed with the number of PID examples and how complicated some of them get.
Thanks
