* Example of PID library.
* 2012 Code by Jason Short, Randy Mackay. DIYDrones.com
#include <AP_Common.h>
#include <AP_Progmem.h>
#include <AP_HAL.h>
#include <AP_HAL_AVR.h>
#include <AP_Math.h>
#include <AP_Param.h>
#include <AC_PID.h>
#include <AC_HELI_PID.h>
const AP_HAL::HAL& hal = AP_HAL_BOARD_DRIVER;
// default PID values
#define TEST_P 1.0
#define TEST_I 0.01
#define TEST_D 0.2
#define TEST_IMAX 10
// setup function
hal.console->println("ArduPilot Mega AC_PID library test");
hal.scheduler->delay(1000);
// main loop
// setup (unfortunately must be done here as we cannot create a global AC_PID object)
AC_PID pid(TEST_P, TEST_I, TEST_D, TEST_IMAX * 100);
AC_HELI_PID heli_pid(TEST_P, TEST_I, TEST_D, TEST_IMAX * 100);
uint16_t radio_in;
uint16_t radio_trim;
int16_t error;
float control_P, control_I, control_D;
float dt = 1000/50;
// display PID gains
hal.console->printf("P %f I %f D %f imax %f\n", (float)pid.kP(), (float)pid.kI(), (float)pid.kD(), (float)pid.imax());
// capture radio trim
radio_trim = hal.rcin->read(0);
while( true ) {
radio_in = hal.rcin->read(0);
error = radio_in - radio_trim;
control_P = pid.get_p(error);
control_I = pid.get_i(error, dt);
control_D = pid.get_d(error, dt);
// display pid results
hal.console->printf("radio: %d\t err: %d\t pid:%4.2f (p:%4.2f i:%4.2f d:%4.2f)\n",
(int)radio_in, (int)error,
(float)(control_P+control_I+control_D),
(float)control_P, (float)control_I, (float)control_D);
hal.scheduler->delay(50);
AP_HAL_MAIN();
why it need while(true)?
when will the function exit the while loop
why it need to test instead of get an initial value to act as the PID 'setpoint' directly?
is it the print test value?
why it need to do that ?
and where is the Kp Ki Kd , because of the test value did't have it
what is AP_HAL main()?when will it act?
I still have problem about radio_trim = hal.rcin->read(0) and radio_in = hal.rcin->read(0)
if this code just test my apm , can I really read the new values ?? and where can I read about the set point
