Hello everyone,
I'm trying to control the RPMs of my 24 DC motor with a HB-25 motor controller and with an optical LM393 encoder to maintain constant speeds (1000rpm, 1500rpm, 2000 rpm, 2500 rpm and 3000 rpm) for a testing period of 1hr.
I choose to use the servo library instead of a PWM signal (analogWrite) to control the frequency of the pulses that are sent to my HB-25 motor controller as the pulses shouldn't be refreshed more frequently than about 5.25 ms + pulse time.
I only want my motor to rotate in one direction (it doesn't matter which one as I can change the polarity manually with my motor driver) so I mapped values of a potentiometer (+5v) to know which servo values (0-255) will allow me to go fully forward in one direction (pulse HIGH: 1.5 to 2 ms) and this are the values I found:
servo at:
94 neutral
136 max speed
I proceeded with the speed measurements with the LM393 optical optocoupler and a disk encoder with one hole.
Here is the code for my measurements:
#include <Servo.h>
volatile unsigned long elapsedtime=0;
volatile unsigned long time;
float tiempo;
float rps;
float rpm;
Servo myservo;
int val;
/* take time to make one turn from the speed sensor */
void docount(){
static unsigned long isrMilis=0; //take the time taken to make one turn (ms)
time= micros(); //save the new time of the interruption
elapsedtime=time-isrMilis; //obtain the period of a rotation
isrMilis=time; // save the time of the old interruption
attachInterrupt(0, docount, FALLING); // attach an interrupt called docount when the hole passes through the hole of the encoder disk
myservo.attach(9); //servo pin 9
val = analogRead(1); // reads the value of the potentiometer in A1 (value between 0 and 1023 )
val = map(val, 0, 1023, 94, 136); // scale it to use it with the servo (94 being neutral and 136 being maximal speed)
myservo.write(val); //write the mapped value of the pot to the servo signal
noInterrupts(); //deactivate interruptions
tiempo=elapsedtime/1000; //pass from us to ms
rpm=(1000/tiempo)*60; //compute the rev per second and multiply them by 60 to obtain the rpms
interrupts(); // activate interrupt
Serial.print("Pulse: ");
Serial.print(tiempo);
Serial.println(" ms");
Serial.print("Speed: ");
Serial.print(rpm);
Serial.println(" RPM");
delay(1);
I still have variations of rpm so I decided to implement a PID control to assure that my speed remains constant.
I obtained the constants of my PID experimentally through the use of the transfer function of my motor and the autotuning block of Simulink.
Here is the modified code:
#include <Servo.h>
#include <PID_v1.h>
float tiempo;
float rps;
float rpm;
Servo myservo;
int val;
double Input, Setpoint, Output;
int kp,ki,kd;
PID myPID(&Input, &Output, &Setpoint,1,1.41941244447319,0, DIRECT);
void docount(){ /* take time to make one turn from the speed sensor */
time= micros();
isrMilis=time;
myservo.attach(9);
Setpoint=1000; //desired speed value to keep RPMs
myPID.SetMode(AUTOMATIC); //turn PID on
noInterrupts();
interrupts();
Input = rpm;
myPID.Compute();
myservo.write(Output);
//Serial.print("Speed: ");
//Serial.print(rpm);
//Serial.println(" RPM");
Serial.println(Output);
delay(1);
but it never activates my motor.
when I change the servo function to an analogWrite my motor rotates, it never reaches the desired value and then shakes due to the specifications of the HB-25 of refreshment of pulses
With all this, several questions came to my mind:
Is there something wrong with my syntax to allow the usage of pid within the servo? or something i should add before writing the output to the servo?
Is there an easier way to maintain my speed in a constant value?
Is there a way to limit the output of my PID as I am also allowing reverse numbers and not only from 94 to 136?
Can I still use the analogwrite (considering the HB.25 criteria) rather than the servo to control the motor to rotate in one direction even though I should refresh my pulses in less than about 5.25 ms + pulse time?
oh here is the datasheet of my motor control Download - Parallax
and i forgot to mention that wondering also if there might be a problem with the definition of my variables as the PID output is a double and im not very familiar with this
Many many thanks for your time,
Andrea
