Hi!
I am trying to control two DC motors with PID control. I have the code for one motor with is pretty accurate. Howevevr, I am not sure how to about having it controlling two motors to reach two different angles?
This is the code for 1 motor and I need it to implement it to 2:
#include <MatrixMath.h>
#define pi 3.1415926535897932384626433832795
int gearRatio = 298;
int ppr = 3;
//motor 1
const int enablePin1 = 8;
const int pin1 = 10;
const int pin2 = 12;
//encoder
const byte interruptPin = 3;
const int pinEncoder = 9; //interrupt pin
//PID constants
double Kp1 = 10;
double Kd1 = 0.7;
double Ki1 = 1;
double demandPosition = 0;
volatile float currentPosition = 0;
double errorPosition = 2;
double errorPosition_diff = 0;
double errorPosition_sum = 0;
double errorPosition_prev = 0;
double Output = 0;
double integral;
volatile long int Position = 0; //count ticks from encoder
float degPosition = 0.0;
float radPosition = 0.0;
int flag = 0;
// Initialize timer
long currentTime = 0;
long previousTime = millis();
double Time;
const int dt = 10; //ms
void setup () {
pinMode(enablePin1,OUTPUT);
digitalWrite(enablePin1, HIGH);
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(interruptPin, INPUT_PULLUP);
pinMode(pinEncoder, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), encoder, RISING);
void loop () {
if (flag==0) {
currentTime = millis();
Time = float(currentTime - previousTime);
if (Time>dt) {
Time/=1000;
if(degPosition>=360.0) {
Position = 0;
if (degPosition<=-360.0) {
Position = 0;
degPosition = (Position*360.0/(ppr*gearRatio));
radPosition = degPosition*0.0174532925;
demandPosition = 90.0;
currentPosition = degPosition;//update current encoder reading
errorPosition = demandPosition-currentPosition;
Serial.print(demandPosition, 3);
Serial.print("\t");
Serial.print(currentPosition, 3);
Serial.print("\t");
//Serial.print(errorPosition, 3);
//Serial.print("\t");
errorPosition_diff = (errorPosition-errorPosition_prev)/Time;
errorPosition_sum += errorPosition*Ki1*Time;
if (errorPosition_sum>255) {errorPosition_sum = 255;}
if (errorPosition_sum <-255) {errorPosition_sum = -255;}
Output = errorPosition*Kp1 + errorPosition_diff*Kd1 + errorPosition_sum;
Serial.print("Output: ");
Serial.println(Output);
errorPosition_prev = errorPosition;
previousTime = currentTime;
if (Output >= 0) {
if(Output>255) {Output = 255;}
else if(Output<70) {Output = Output+70;}
else {
if(Output <-255) {Output = -255;}
else if(Output>-70) {Output = Output-70;}
if (Output >= 0) {
analogWrite(pin1, round(Output));
analogWrite(pin2, 0);
analogWrite(pin2, round(-Output));
analogWrite(pin1, 0);
void encoder() {
if(digitalRead(pinEncoder)==LOW){
Position++;
}else {
Position--;
Thank you
