PID Control
My output is always being set to 0 whenever it does myPID.compute(). Why is this the case?
#include <PID_v1.h>
double Setpoint;
double Input;
double Output;
double Kp=0.256, Ki=29.412, Kd=-0.0008439;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
Setpoint = 1000000;
myPID.SetMode(AUTOMATIC);
myPID.SetTunings(Kp, Ki, Kd);
pinMode(A1,OUTPUT);
pinMode(A0,INPUT);
analogWrite(A1,900);
delay(5000);
Input = analogRead(A0);
myPID.Compute();
analogWrite(A1,Output);
//Serial.print(Input);
Serial.print(" ");
Serial.println(Output);
//Serial.print(" ");
//Serial.println(Setpoint);
Double is implemented as float, no extra range or precision. Can that affect Your cide?
Pid needs to be connected in a control loop - an output and an input to show meaningful values .
Also , you may need to change the control sense normal/reversed .
It's your negative Kd setting. Running your code on an Uno with nothing on A0, I get zeros too. As soon as I make Kd non negative, it gives 255, which given your huge set point, makes sense.
You'll need to dig into the library to see why, perhaps take a copy and then put some Serial prints in there to see what it's doing.
I'm no PID expert; does a negative Kd actually make sense?
